Home > Maintenance & Mods (L322) > Handbrake cable replacement 2002-2006
I've tried to follow his guide and am stuck on he centre console by.
http://www.fullfatrr.com/wiki/Handbrake_cable_replacement
Pictures would speak a 1000 words but there aren't any so as I go I'd like to add some but from the way I read it am I correct in saying it's not the finisher panel under he rear vents that gets removed but in fact is the whole centre console after you lift the arm rest and remove the two torx head bolts from under the little plastic/rubber tray? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #418831 20th Dec 2016 4:12pm
Says in Rave to remove the entire center console, you maybe able to do it with removing less but doesn't look easy.... Pete
Post #418859 20th Dec 2016 6:18pm
Don't need to remove the entire console, just the rear panel which will give you access to the cables. Watch your hands, the metalwork in there is razor sharp and if you can do it without cutting yourself then I will buy you a pint Laughing Laughing Laughing
Post #418898 20th Dec 2016 10:04pm
Ah cheers John Smile
Do you mean the lower panel on the rear under the vents, or just by pushing the rear up a few inches?
After working for years in IT I've learned about sharp metal in tight spaces sonill not be getting any cuts!
Not spotted anybheat shields cover the cable before it ducks inside the car so hoping that makes the job a bit easier for me and I'll use the old string and ductape method to help guide it in Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #418903 20th Dec 2016 10:19pm
I think I completely remover the lift up lid/cover and tray, then the lower panel which is held in place with push in plastic pins and possibly a couple of Posidrive screws down the bottom. Sorry I can't be more help Will, it was a few years ago now and the old grey matter isn't what it used to be. Once you have a look and see it, it's fairly straight forward and simple enough to do, just don't drop the plastic clips as they are a nightmare to find again....That much I do remember Laughing Laughing
Post #418925 20th Dec 2016 11:36pm
Well I've replaced the cable with no skin lost! I still need to refit the hub and connect it at that end but I think and hope that will be much easier than the interior but!
It was quite fiddly with the ball release but at least having a dedicated tube guide to feed it up helped a lot but I played it safe with the string/old abs sensor cable and ductape method Smile
If someone had to do the passenger side one it would be super fiddly due to access at the centre console and I wouldn't want to try and push it any higher up than I did!
To release the cable it needs to be pushed up from the other end and then pushed towards he centre of the cable device and whilst being held there pulled out using he other end of he cable again.
Fiddly with such little space but it becomes clearer when it's In Front of you and you see the cable bulb at the end of the cable FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #419339 23rd Dec 2016 6:32pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Well done kp.
glad you're sorted.
Good pics btw. Hope i never have to do mine.
Post #419358 23rd Dec 2016 8:13pm
When i get to the hub part I'll try and get some pics or at least a video, I imagine it shall be fun!
Why oh why did thy use sodding drum brakes when cable operated calipers are so cheap and much easier to install, Christ the French have been doing it for more years than I've been alive and had it working perfectly fine! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #419395 23rd Dec 2016 11:52pm
gregdav
When I replaced my brake shoes, found it a little bit fiddly to keep the cable attached to the pull pivot thing, had to watch closely when putting the disc back on, so it didn't come off.
your right about the design though, for an upmarket motor, it's a bit antiquated.
Post #419419 24th Dec 2016 8:43am
What's the betting though that Solihulls finest have done a 'stick to wot we no best lad' approach on their newer generation of vehicles Wink Very Happy FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #419421 24th Dec 2016 9:11am
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
I had the same issue with the cable locating into the slider. Once the shoes are on & held in place with the pins then it's ok.
Still doesn't install confidence though & agree much better with a cable operated caliper.
Plenty of video clips around showing the setup. Thumbs Up
Post #419429 24th Dec 2016 10:31am
Rihouey
France
Hi
I am working on the handbrake cable replacement, and i am Looking where this special pin Is located ?
I have read all the threats and di not have any answeer ?
Is anybody get a photo or a drawing showing this pin location?
Thanks for your help RR 2005 td6 HSE 197000 km
Volvo V70 D5 205 cv 2010
911-996 2001
Mini Clubman 2009
Fiat Panda 1991
Post #473670 24th Mar 2018 8:23am
Rihouey
France
Finally i do it without pin, using a piece of wood to maintain the cable connector out of main cable pressure,
Job is done. RR 2005 td6 HSE 197000 km
911-996 2001
Mini Clubman 2009
Fiat Panda 1991
Post #473704 24th Mar 2018 3:56pm
RaveRover
Australia 2005 Range Rover HSE 4.4 V8 Java Black
Hey. Ive got an issue with my handbrake cable on my L322. I've adjusted the handbrake pads right up and backed off 3 - 4 notches, recommended is 8, I know.. but still have a slack handle.. only engages high up in the travel. The drivers side rear wheel rattles too whenever I hit a bump in the road. I think its the end of the handbrake cable flapping around against the internal handbrake lever mechanism.. I say this cos when I reef up the handle while driving the rattling stops. I suspect a stretched cable. I keep getting told its auto adjusting and doesn't need any adjustment except for the normal " flat blade screwdriver in the 6 o'clock hole". So I'm at a bit of a loss. Rolling Eyes Handbrake cable? or something else?
Thanx Matt Thumbs Up
Post #480754 12th Jun 2018 11:32am
RaveRover
Ok, I've since lifted the rear of the console with the handle down, to reveal the cable linkage and found that the whole thing is tilted probably as far as it can go. 1 side is tightish but not actually activating the brake.. and the other side, drivers side, is so loose that when I push the tilt mech down with my finger to level it out, I can grab the ball end of the cable and pull it up about 40mm above the mech itself.. So there's def something wrong here. My first thought was that the ball had slipped up the cable, but on comparison with the other side, looks ok. I'll have to recheck the fitment of the other end in the handbrake drum, may have stuffed that up. Rolling Eyes
Post #481120 17th Jun 2018 7:32am
