![]() | Home > Technical (L322) > Rear wheel alignmentd |
| Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 481
Further to my post about my car handling like |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
The toe link and the upper hub bush both have eccentric bolts, therefore both may need adjusting for correct alignment.
Thanks for the reply as always |
Oh god that sounds like a horror story!
| holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086
This was the very helpful thread i followed
Thanks for your help
You should be able to find the parts easily, don't forget you needs nuts bolts and washers and give the bolts a good grease up before putting them back through the bush
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
Don't be tempted to use pattern parts, they fail very quickly, get genuine or OEM. Dan at Duckworths will sort you a good price on OEM parts as well as Genuine... |
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
If the dealer doesn't have them in stock they are easily able to get them next day, they are about £12-14 per bolt with washers and nut.
| All times are GMT |
