Home > Technical (L322) > How to Find Top Dead Center TDV8
Page 10 of 12 <123 ... 9 101112>
I'm sorry but I have to disagree, if it was running fine then suddenly cut off and wouldn't start them I can't see it being a head gasket, it wouldn't lose enough compression over 8 cylinders to cut out in such a short period of time, if one gasket failed, and it's unlikely to have a dramatic 4 cylinder failure, then it should still run like a pig on the other side, if it started to run bad then cut out it sounds more like a fuel issue, especially as it now starts with a bit of easy start.
Do you have an IID or similar that you can use to work your way through the live values..??
Having said all that I agree a compression check is a quick and easy thing to do to rule out issues... Thumbs Up Pete
Post #419447 24th Dec 2016 1:08pm
rar110
No worries Pete. It's really a guessing game without more info.
I agree a compression test is something that will help no arrow the field. ______________________________
Post #419456 24th Dec 2016 2:23pm
Matt_980
Hi
Were the injectors in the damaged cylinders checked or replaced?
Agree a compression check would give a good indication whether mechanical or electrical.
Matt
Post #419523 25th Dec 2016 9:57am
theanswers
Ireland
Hey Everyone.
Hope you all are enjoying your Christmas Day dinners!!! I've eaten plenty of food so should have enough energy to tackle back into this RR!
Anyways; Haylands - Thanks for that ray of hope, hopefully you are correct. I do have a IID tool so should be able to read the live values. This should shed more light.
@Matt_980 I the injectors where not replaced or checked, perhaps there is something wrong here.
So. This is my POA
1/ Check Injectors Live Readings
2/ Check Turbo's
3/ Check Compression.
4/ Check in Tank Pump
This should narrow the whole saga down. Thumbs Up
Post #419545 25th Dec 2016 5:49pm
theanswers
Ireland
I went at the RR today. Gave the battery a full charge overnight and connected her back up this afternoon.
It started first turn of the key.
White smoke initially wasn't so bad, but then got worse as the engine got slightly warmer. Managed to get values using my Handheld.
Injector 4's value are well off everything else and don't change when rev'd. Could this is the issue? The readings where taken at idle.
Post #419765 27th Dec 2016 6:48pm
Sorry, don't know enough about the fuel of the devil but I'd swap the injector with another one to see if the problem swaps with it...
Good news on it starting though.... Thumbs Up Pete
Post #419776 27th Dec 2016 8:03pm
theanswers
Ireland
I must try and find out which cylinder the injector corespondent too, as I don't think they match with the same cylinder number? I've got a new error code tonight. P0266 Cylinder 2 Contribution/Balance Fault. Probably related to this.
Post #419786 27th Dec 2016 8:49pm
proser
Whilst the engine is running and you have live values, can you pull the plug off one of the injectors and see what it corresponds to on your diagnosis tool.
http://www.fullfatrr.com/forum/post219147.html this is another post that shows the layout of the cylinders. Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #419792 27th Dec 2016 10:19pm
Mikey
Issue is with Cyl 4, overfuelling, massively Thumbs Up
Either a faulty injector or low on compression. Injectors can be swapped to see if the fault moves with the injector, or stays on Cyl 4
If it moves, it's a faulty injector Mr. Green
If it stays, it suggests a compression issue Big Cry
Post #419810 28th Dec 2016 12:51am
Mikey
DO NOT unplug an injector when the engine is running Shocked
You risk causing irreparable damage to the PCM internals Rolling Eyes
Post #419811 28th Dec 2016 12:54am
theanswers
Ireland
I have a spare injector. I'm going to change back to that one tomorrow on Cylinder number 4.
If I recall correctly that was the original damaged cylinder.
We changed the original injector to another old one to check if it was at fault. It was never changed back. Therefore, hopefully it is this second hand injector that is causing the trouble!!
Fingers Crossed. Would be strange to lose compression like that, when all was well.
Post #419812 28th Dec 2016 1:03am
theanswers
Ireland
When I put revs on the engine all cylinder including number 4 display the same readings.
Post #419813 28th Dec 2016 1:04am
theanswers
Ireland
As I mentioned earlier.
I think the fault is in cylinder number 2 with injector number 4.
We will soon find out!
Post #419814 28th Dec 2016 1:21am
theanswers
Ireland
Ok.
So I've changed injector number 2. Safe to say that was the problem with regards to the lump idle/ majority of white/ blue ish smoke. All injectors are now balanced.
I've left her idling now to get up to temp. There is still a small amount of smoke from the drivers side exahust. Would this disappear with a run? It whitish, blueish in color.
Post #419834 28th Dec 2016 1:32pm
theanswers
Ireland
Unburnt fuel from last nights idling.
Post #419835 28th Dec 2016 1:39pm
