![]() | Home > Technical (L322) > How to Find Top Dead Center TDV8 |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 ![]() ![]() ![]() |
Old fuel could be coating /pooling in the exhaust - should burn off - as long as there is nothing else addint to it.
theanswers Member Since: 30 Jul 2012 Location: Ireland Posts: 305 ![]() ![]() |
Very Strange.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1847 ![]() ![]() |
If there has been that much fuel passing through the engine and exhaust, there will be smoke for quite a while I would expect
I'm not sure exactly on the oil level, perhaps tomorrow I will change it all just to be certain. Took her for a test drive this evening about 12 miles. Still smoking all though not as bad as previously. I'm starting to think there is two separate problems.
This does not happen in neutral. All though the smoke can still happen in neutral.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8719 ![]() ![]() ![]() |
Italian tune up for 20+ miles then re-evaluate.... |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
You don't have any splits in the pipes do you?
I'm going to try and do a bit more driving tonight. I would be very surprised if they failed. I replaced the RH (Passenger) one less than 5,000 miles ago.
If at tickover then there is no pressure so it should feel the same as it does with the engine off, if one is harder than with the engine off that would indicate a blockage somewhere I would think.... |
Hey Everyone!
Is the woosh related to engine speed?
I don't think it is the alternator, I'm almost certain it is a intercooler hose related and the reason being is tonight whilst driving it flash engine system fault, promptly I plugged in my handheld and it send boost pressure manifold Bank a correlation error. Which side is that? Switched on and off and all was well. |
Any use? http://www.fullfatrr.com/forum/topic36280.html?view=next Ed |
