![]() | Home > Technical (L322) > 4.4 tdv8 12MY restricted Performance |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
Hi there, was wondering if anyone has experienced or could shed light on this.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3852 ![]() ![]() ![]() |
It might be worth getting the turbo air change over valve checked.
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 ![]() ![]() ![]() |
Could it be slight degradation / split in one of the hoses from intercooler to inlet manifold? They're well known for failing (on 3.6 TDV8, anyway - can't see why it would be any different on a 4.4). The top two hoses are fairly easy to get at and inspect. My thinking being that a split might only open up under pressure, which would explain 3k trouble-free miles between problem.
Hi Steve, good point, although it is used hard between the 3k miles so i am not sure as its not a consistent fault. will check the hoses. Cheers
JST,
thank you Cheers
still does it, hoses are good.
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 ![]() ![]() ![]() |
I had a similar issue last year whilst in France and it turned out to be a cracked inlet manifold. The French mechanic demonstrated it by standing on the accelerator whilst I held my hand over the manifold. Lots of air escaping from the split manifold. It appears the split only caused an issue when the car was on a long climb with the caravan on the back, I.e. Under load. |
cheers Buzz, that has been suggested previously and your comments help reassure this. was that on a 4.4? i am aware of is it being a problem with the 4.4s Cheers
Hi James, yes, a 4.4 |
thank you. Cheers
The Flying Scot Member Since: 09 Apr 2009 Location: Surrey Posts: 77 ![]() ![]() ![]() |
Hi JST,
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
Hi Tony,
hello,
