![]() | Home > Technical (L322) > TD6 Problems (Update) |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3269 ![]() ![]() ![]() |
Yesterday went shopping with the FF. On returning to the car it would not start and in the end had to get recovery out.
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
Would have said starter motor or starter solenoid but if you can't turn the key to the start position key and/or ignition lock/switch must be suspect as you have already thought?? Mine was a blue one! |
Thanks, Andy. Tried everything else so have ordered a switch from Dan. Hopefully that will do it.
Hello John
PS
scuddriver Member Since: 12 Feb 2015 Location: Dunbar Posts: 140 ![]() ![]() ![]() |
I had this a while back and it turned out to be the ignition lock ECU. There is a thread about it and a link to a pssible solution here:
Andy, Just down the road |
Turned out to be the ignition switch right enough. Replaced and now running. Just got to put the centre console back |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
There has been a thread on AULRO in which the switch was removed, contacts cleaned with a good result. Pictures to show how..https://www.aulro.com/afvb/l322-range-rove...tch-2.html 2007 TDV8 VSE
Interesting thread. |
