![]() | Home > Maintenance & Mods (L322) > battery drain |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
Have you tried charging the battery up fully and then disconnecting the battery -ve terminal and then leaving the car overnight? |
vmaxer Member Since: 22 Jun 2016 Location: staffs Posts: 110 ![]() ![]() ![]() |
right i spent all yesterday checking all sorts of things |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3666 ![]() ![]() |
FBH is std on TD6 |
if only i had the hand book |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 ![]() ![]() ![]() |
goto https://topix.landrover.jlrext.com register and then put your VIN number in. click on documents on the right and then it will give you an online copy of your handbook to browse on the left. Regards
thanks mark |
Show n shine Member Since: 01 Jun 2016 Location: Hertfordshire Posts: 55 ![]() ![]() ![]() |
had this issue on my fullfat I though it was the final stage resistor. but was not. locked the car and checked to see if the red lights turned off. they did.
nar53 Member Since: 05 Nov 2015 Location: Le Mans Posts: 120 ![]() ![]() ![]() |
[quote="miggit"]FBH is std on TD6 |
its under the battery tray if you have one fitted |
Thanks vmaxer, I don't think it has one but miggit suggests that all TD6's have them.
The FBH was std on diesel cars, if you don't have one then it has been removed, rather than not fitted |
How loud is the fan ? when you unlock your car and open the door you will always hear a fan that cools the ECU's just ahead of the front bulkhead behind the battery by drawing in air from the cabin. 2008 MY Supercharged
new battery and all good |
