Home > Maintenance & Mods (L322) > Washing
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Washing
Just cleaned my range rover and can see the swirl marks\scratches coming back, only buffed it 4-5 months ago. I use the two bucket method and a wool mit but today it was so filthy as soon as i touch it i must be adding scratches. Also wondering if when i buffed it i just masked some of the scratches and now the wax is fading thus there showing again.
Bolloxs to wasting a whole day next year buffing a black car again and i think i just do the tenner in and out job up the road for a quick wash too.... Big Cry 2004 black Vogue TD6
Post #41987 12th Dec 2010 4:42pm
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
I think as soon as you touch the car, the swirl marks appear - modern paint is that soft. Two buckets, grit traps and sheepskin Mitsubishi only reduce the damage and prolong the period before you need to buff again.
One thing that helps in these times is a snow lance. I usually do two applications at this time of the year. If you have a good coat of wax on, most of the crud will drop off, so you are then cleaning an almost dirt-free car.
Post #41995 12th Dec 2010 5:07pm
dan_uk_1984
Re: Washing
When you say you "buffed" the car... what products did you use?
Dan
Post #42003 12th Dec 2010 5:37pm
td6 vogue
Black car needs a lot of love! Wash with plenty of clean water then polish ,and or wax monthly. Thumbs Up
Post #42005 12th Dec 2010 5:41pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
+1 for snow lance.
I waxed with fk1000p and now I can do a 95% touchless wash.
Pressure wash, then foam & spray wheel brite gel then pressure wash down again.
Pretty good for winter.
http://gallery.me.com/stephen.wood125/100003/Rover1
Post #42006 12th Dec 2010 5:41pm
letsavit2
Re: Washing
Dan
purchased this: http://www.cleanyourcar.co.uk/polishing-ma...d_721.html
then finished with some NXT wax i had, was happy with result. Dont know if its effects are fading or i'm adding swirls again, think its the latter. 2004 black Vogue TD6
Post #42012 12th Dec 2010 6:07pm
letsavit2
Think i need to google this this snow lance stuff.
To be honest this time of year i want a quick easy wash that cleans the salt off and adds no damage, not worried about finish, few streaks etc. Ill spend some time and get her looking good again in spring. 2004 black Vogue TD6
Post #42014 12th Dec 2010 6:12pm
dan_uk_1984
To get rid of swirls you have to cut the paint, ideally you'd only want to polish twice a year really. I generally do a hard polish when I buy the car, followed by a couple of coats of wax. Then every 6 months do a light polish and another wax.
Then weekly I use Autoglym Aquawax, great on dark/black cars.
The result of all this is that barely any dirt sticks to the car, so a very light passover with a lambswook mitt is all that is needed.
It is a full days hard work, but then you only have to do it twice a year. If you find it that tedious you can pay a detailer to do it for you.
For further reading; Andy has done a great writeup on detailing here: http://www.fullfatrr.com/wiki/Detailing
Post #42015 12th Dec 2010 6:20pm
letsavit2
yea, think ill just have to give it another quick polish in spring, its the first time i have done it and was hard work so hoping it would be a once a year job.. Whistle
that foam stuff looks good, getting rid of most dirt before touching with a mit can only help 2004 black Vogue TD6
Post #42035 12th Dec 2010 7:58pm
T24RES
I took advantage of the group buy offer over at DW and bought a snow foam lance................ Thumbs Up Ian
Post #42094 13th Dec 2010 12:09am
Stephen.125
http://gallery.me.com/stephen.wood125/100003/IMG%5F0636
Lance from CYC via Detailingworld and Autobrite group buy 5 Magifoam.
Picture is after 15 minutes!
Also got a DAS6-pro from CYC Menzerna kit- really want to try it!
Post #42098 13th Dec 2010 12:40am
letsavit2
ok i'm converted.... Laughing
Got to check what my pressure washer end looks like then ill look at buying the gear. 2004 black Vogue TD6
Post #42198 13th Dec 2010 8:05pm
