Home > Maintenance & Mods (L322) > Vacuuming Oil 4.4tdv8
I was going to do an oil swap with the vacuum pump I got to do SWMBOs car, coincidentally I had the part I ordered off Dan arrive a week or so back, it's the "dipstick tube" which goes from the vac point down to the push on fitting at the bottom of the sump.
Hmm my draw off kit hasn't got anything in the way of an adaptor to go on the top of the tube and I don't think it's wise to push it down the tube!!!! Looking at all the bends i can now see why it has an electronic dipstick!! Looks like I will have to take the bottom off.
Anyhow a warning to all those who want to do a suction change. Stick the vac on the end of the pipe. There is nothing that can't be fixed with a hammer😜😜
Post #420145 30th Dec 2016 11:48am
Baltic Blue
When you have changed the pipe, please will you take a more detailed closeup photo.
I am trying to figure out if I can make some form of easily fitted adapter for a better seal using a vacuum pump.
No rush because I have one more full service included in my warranty package, but I intend to do as much servicing as I can after that.
Cheers & best wishes for 2017. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #420154 30th Dec 2016 1:02pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
SWMBO has brought me a Draper 'expert' 10 litre hand / pneumatic vacume pump for xmas which comes with a whole range of top pipe fittings. Took 5 weeks to arrive FFS - only just in time for Santa to put it in his sack!
Not used it yet but it does look the canines testicles. £90.00 delivered. I would have assumed the cover needs to be fitted over the small outlet tube and not down it. Looking at the pic I can see why!
Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #420158 30th Dec 2016 1:13pm
The cap is push and twist which leaves just an 8mm pipe end to attach onto.
My vac pipe is 5.8mm so I need an adapter. There is nothing that can't be fixed with a hammer😜😜
Post #420168 30th Dec 2016 2:08pm
