![]() | Home > Technical (L322) > Jump starting |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8108 ![]() ![]() ![]() |
Maybe not enough power through the booster pack ?
Wogger Member Since: 12 Jun 2016 Location: Nottinghamshire Posts: 407 ![]() ![]() ![]() |
On to recovery firm now !!!
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 ![]() ![]() |
Had the same issue a few weeks back. Suspect the battery is shot. The breakdown guy attached the booster pack for about 15/20 minutes before trying to start the engine and it fired up first time.
Cheers |
Think it is the battery.
Not experienced the one you mentioned. I got this from ATS :-
Thanks for wise words chaps.
The battery should fit well & be completely free of movement.
Cheers Alistair
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
Careful with a jump. If your battery is totally dead, you'll put a lot of strain on the alternator once it starts up. If the situation allows, charge up the battery first, or replace. Good luck. |
I've got a suspicion that the alternator is the problem |
