Home > Technical (L322) > How to Find Top Dead Center TDV8
Page 12 of 12 <123 ... 101112
hamlet
Ireland 2006 Range Rover HSE Td6 Buckingham Blue
Delighted you got it going, Hopefully your current problem is an easy fix......... Thumbs Up
Post #420466 31st Dec 2016 8:40pm
Mikey
Double check the hose clips are all tight, especially the little red one on the turbo. Fiddly little Censored but needs must Thumbs Up
And also the hose onto the Intercooler, obviously
Post #420499 31st Dec 2016 11:06pm
theanswers
Ireland
That link worked perfectly thank you!
Now at least I know which side to examine. Definitely there is air escaping. It's going to be tight to get at the pipes, but I'll give it my best shot!
Might go at it after dinner.
Post #420573 1st Jan 2017 3:54pm
theanswers
Ireland
I checked the two top manifold pipes today and couldn't see any side of a fault such as a rip.
What is the easiest way to access the LH turbo below (Bank A) so I can check those pipes.
Also the RR is back draining the battery - and I receive an error Fan Circuit 1?
Thanks!
Post #421092 4th Jan 2017 11:33am
Mikey
LH turbo isn't easy to get to Big Cry
Post #421113 4th Jan 2017 1:59pm
theanswers
Ireland
Oh no! I'll have to try harder so. I was hoping there would be a quick fix!
Also the battery is going flat overnight... Might give it a good charge and tighten the battery terminals.
Thanks again lads. When this is all over, I think I'm going to do a big write up!
Post #421203 5th Jan 2017 12:24am
Mikey
Dare we ask, any news?
Post #424352 22nd Jan 2017 11:38pm
theanswers
Ireland
Hey Guys!
You may dare, of course! Still hoping to do that write up. But as of yet, I'm not fully out of the woods. It's insight but I'm not there yet.
The turbo issue for the most part turned out to be a split intercooler hose, which I had missed. I replaced it and not the power is much better. However! If one fully revs the car whilst accelerating it still sometimes goes into Engine System fault. I think it's a turbo actuator, but I'm not sure.
Also if left over night it will drain the battery flat. This is something it wasn't doing before. I'm not sure where to start with this, so I just currently disconnect the battery. Any ideas chaps?
Likewise also on my to do list is;
a) Fix drivers heated seat
b) Fix parking sensor front loom (mechanic damaged this when removing the bumper)
c) Fix drivers lock - it doesn't do anything, so I have to leave the car unlocked.
d) Fix thermometer Both Engine Temp & External.
That's it!
Post #424387 23rd Jan 2017 10:40am
