Home > Technical (L322) > Forgive my ignorance...
Andy
.... but having never owned a vehicle with Xenon headlights before, what is meant by "Bi-Xenons"?
It suggests to me that it is as it states "Bi" meaning two. However, I can't see any other light in the unit appearing to be a xenon unit. So where is the second one?
Finally- has anyone ever found a nice replacement bulb for the side lights, to make them look a bit whiter? The ones I have appear yellowy alongside the headlights 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #4192 26th Mar 2009 10:56am
ken
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Bi Xenon Both Dip & Main are Xenon although backed up by halogen as well for flashing cars Whistle
If you have bendy lights its best not to change to a led side as leds dont react to heat to well
Try UltraLED .co. uk or the like with LEDS like most things you pays your money flea bay ones are crap Thumbs Up
Post #4196 26th Mar 2009 11:09am
Full fat not diet
England 2004 Range Rover Vogue Td6 Zermatt Silver
Noddy, There are a couple of posts on the RRS site for changing side lights to LEDs. Have a hunt and read if you plan to change them as some are better than others.
Post #4202 26th Mar 2009 11:48am
When I had my M5 there were always other Beemer drivers looking to make their cars look like they had blue/xenon lights. You can buy the same bulb replacement in a higher Kelvin blue output that simply swaps out. That's got me thinking, I might even have a set in the garage I can put on mine...going to check. Discovery 4 HSE
1993 90 Tdi
Post #4206 26th Mar 2009 12:35pm
Larry
England 2006 Range Rover SE Td6 Java Black
Has anyone actually changed the sides for LED's?
It's just that most modern cars fault detection systems get a little upset by LED's as they think that the filament bulb it thinks should be fitted has blown and keeps telling you with annoying little lights and beeps. Maybe this doesn't happen on FFRR's.
The superbright halogens are good. Had them on previous cars, but did throw up the same problem of side lights looking yellow against them (hence me knowing about the LED upgrades causing problems).
Halfrauds have a periodic deal on the +40% ones every now and again (BOGOF) that is very competitive (actually makes them cheaper than competition for once).
Post #4209 26th Mar 2009 1:25pm
Full fat not diet
Larry - i know of the problems but cant remember the solution - it should all be on the RRS site as loads of the guys swap to LEDs - if i recall one of the us chaps knows about it - cant remeber his name but i will have a look
Post #4210 26th Mar 2009 1:31pm
ken
Front sides are OK (for LED) LED for indicators are another story Shocked
Post #4216 26th Mar 2009 2:34pm
Mudplugger
England 2016 Range Rover Vogue SE SDV8 Waitomo Grey
Sorry Ken - didn't work for me.
As they were OK in my D3, I tried some white Ultra LEDs as sidelights in my 09MY Vogue FFRR.
I don't have the adaptive lights.
The LEDs and the FFRR didn't get on at all.... warning messages all over regards the sidelights being blown, and also at tickover - a real 'flicker' coming from the LEDs - presume as they must run straight from alternator supply.
Took them straight out, and in the end just used some heavily blue tinted/different colour temp ordinary capsule bulbs - and they appear white now.
I've used the LEDs in the front map lights - more directional and better colour rendering at night of a map/directions etc..
Bit odd, as my D3 had adaptive lights (don't actually miss them in the FFRR - nor do I think they are that much better, even though I thought I would) and I had LED sides, tail, stops and numberplate - only indicators were a pain as they needed a resistive load. Couldn't see the point of having a resistor in the circuit to mimic the load - so stuck with bulbs...
All those LEDs worked fine and never threw up a message...
The FFRR is obviously more sensitive... Rolling Eyes
Muddy Range Rover Vogue SE SDV8 - L405 (now sadly sold)
BMW i3 (fantastic little runabout)
Kioti NX6010 Tractor
Yamaha Big Bear ATV
And a whole heap of other kit...
Post #4281 28th Mar 2009 11:29pm
Full fat not diet
Mudplugger, Do a hunt on the RRS site re LEDs - Many on there have changed them some with and without sucess initially - I know that some LEDs work and some dont and you should find the answer and what and where to buy on there. Let us know how you get on Thumbs Up
Post #4289 29th Mar 2009 2:12pm
Andy
I've just bought these - not sure if they'll work, but for the money, its worth a try. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #4291 29th Mar 2009 4:34pm
dantheman
I've just bought a couple of replacement bulbs, but laser blue (LB). Paid about £1.60 down from £4 at Halfords with trade card... Don't know if they're any good yet - will find out later and let you know.
ref your LEDs noddy: please keep us informed as to whether they're a vast improvement. Thumbs Up
Post #4292 29th Mar 2009 5:06pm
Mudplugger
Hi FFND Noddy and all,
Have just looked at the GTR on the web and viewed the circuit diagram, and had a sneak look at the LR resource online (courtesy of friendly JLR development engineer).
The blown bulb sensing appears to be measured in the control module based on a filament bulb fitting between two current consumption parameters defined in the software control module. These parameters appear to be set to around 10% eaither side of the acceptable range of current consumption of the average 12V 5W incandescent (tungsten filament) wedge bulb.
It would be possible to fit LED's and a resistor (to mimic filament current consumption) and fool the software - or one could see if it's possible to alter the software parameters (or switch bulb warning off).
This works very similarly to 'electric over oil' solenoid hydraulic controls in a modern tractor - that also have software parameters that give error messages when out of ranges - normally indicating poor implement connection, reduced flow rates or blown seals.
In short - yes, it can be done for the FFRR - by choosing an LED cluster that is designed to mimic a filament bulb, or by applying an external resistor into circuit (which turns the required current into heat rather than light) but it does seem a lot of hassle for little return.
For those of you who like to know these things its currently around 417mA a bulb assuming 12V and 5W (so 834mA or 0.8A for 2). A typical 4 LED cluster only draws a maximum of 80mA (0.96W)- so even a pair of these falls well outside these parameters.
The resistance required to consume the additional current then is only about 35 Ohms but not surprisingly would need to be rated at about 4 Watts in order to safely turn the extra current into heat. These resistors are called power resistors and all of them have some form of heatsinking capability and importantly - they get HOT! (often with surface temperatures exceeding 200deg C)
I'm not sure I'd want to swap a perfectly serviceable filament bulb for LED's and a heat source... Shocked
The RRS and Discovery 3 utilise the same (but very different from the FFRR) control module - which only looks at 'key circuits' these being headlamps and stop/tail lamps. Since stop/tail lamps have many more than 4 LED's - I'm assuming that the current consumption creeps into the low end of the parameters and would not set the control module to show a fault. The sidelights are not covered by this control module (one can blow and you won't know until you get out and look) and thus are fine with LED's which draw little current..
My own view is that I have more interesting things to play with just now - but if I'm bored one summer afternoon, I may just get the power resistance decade box out of my workshop, and plot the parameters set for a fault condition. Then you could choose the LED array and minimum resistances needed to make a true LED sidelight work and give a fault if it ever went open circuit...
Alternately - I could just stick with the filament bulbs, sit back and relax! Thumbs Up
I think Noddy will find the same as me - that the software in the FFRR will keep telling him his bulbs are blown. The LED's will work fine - but may flicker at tickover...
Let me know if it's just my FFRR - or if others get the same result!
Regards,
Yamaha Big Bear ATV
Post #4293 29th Mar 2009 5:09pm
