Home > General > My new best garage tool
Biffo
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Just thought I'd share this. I'm doing some work on a Freelander 1, and was struggling to get the front driveshaft nuts off (tightening torque is 400Nm) Twisted Evil
I broke a decent quality ratchet, broke my old "undo anything" torque wrench, bent one 1/2 inch drive breaker bar and came close to snapping another one Big Cry
Then I saw an old post on another site, just a one liner ignored by the other posters, mentioning a torque multiplier - but it also said how expensive they were. So I did a search and my, have times moved on - I went ahead and bought one on eBay (alright, its not going to last forever - but then I don't intend doing this job many more times !) - for £26 delivered, including the right 32mm impact socket Shocked Thats WAY cheaper than buying a 1 inch breaker bar and appropriate socket, which was going to be my next move.
It arrived today and I went straight out to the garage to give it a go, not overly confident of success if I'm honest - and it promptly undid both driveshaft nuts like they were finger tight !! What a great bit of kit Thumbs Up
Post #420987 3rd Jan 2017 7:01pm
Link..?? Pictures...??? Pete
Post #420991 3rd Jan 2017 7:09pm
Wow - I'd never seen or heard of these before
Interesting find Thumbs Up
Post #420992 3rd Jan 2017 7:12pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Chap down the lane from me has one, he's a retired hgv mechanic.
good bit of kit.
Post #420995 3rd Jan 2017 7:16pm
mzplcg
Ordered Thumbs Up
Not sure what I'll use it for yet but nice to have in reserve.
Post #420998 3rd Jan 2017 7:28pm
proser
HGV mechanics and breakdown guys tend to use them for helping to replace wheel on the side of the road and generally in the garage.
Used to be mega expensive, but as you say times have moved on and the chinese imports have taken over Smile Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #421001 3rd Jan 2017 7:56pm
unsolicited
United Kingdom 2017 Range Rover 5.0 SC V8 Mariana Black
When undoing the crank bolt, what did you use to brace the reaction arm* thingy on the multiplier?
*I've no idea what the correct term is for this.
Post #421006 3rd Jan 2017 8:11pm
Rangeyman
Am fortunate to have a 3/4 inch drive set ,which is great for very tight stuff if you have room to get the sockets on !
Post #421018 3rd Jan 2017 9:10pm
Something like this me thinks
https://www.ebay.co.uk/itm/Labour-Saving-T...SwFFZbDQJZ
What is going on inside the big tooly bit? Gearing ?
edit: updated link 07/04/2019 .
Post #421031 3rd Jan 2017 10:13pm
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
Post #421035 3rd Jan 2017 10:31pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
I purchased one of these a while ago for around £30 never used it but looks good bit of kit originally got it for wheel nuts on my ldv 400 recovery truck just never needed to change tyres away from home where I have my air driver
Post #421045 3rd Jan 2017 11:10pm
Looking like a must have for lower bolts on the front struts Thumbs Up .
Post #421056 4th Jan 2017 12:09am
Weegie
Looks ideal for removing nuts. Can it be used to tighten nuts to a particular torque setting? John
GAP iiD BT-Sold
Post #421088 4th Jan 2017 11:11am
Sandyt
Like others didn't know such things existed
Ha best I order one as if I dont you bet I will need one in the next few weeks
As they say anything can happen in the next half hour
Post #421094 4th Jan 2017 11:59am
Biffo
Sorry, been busy on the Freelander all day today Evil or Very Mad
Yes, the pic put up by Joe90 is very similar to what I bought. Great bit of kit Thumbs Up
To answer unsolicited's question, I was undoing the hub nuts on the front driveshafts and braced it against a wheel stud. I tightened a couple of flat bottomed nuts onto the wheel stud first though. These protected the thread, and gave a much firmer base so the stud didn't bend. With a bit more time (patience ??) I would have fabricated something that fitted over 2 or more studs and bolted down.
I did read you could do nuts up by setting your torque wrench using the multiplication ratio quoted for the tool but I don't think I'd trust it Shocked My plan is to crank the nuts up using the breaker bar then take it to a garage with a big torque wrench.
Post #421157 4th Jan 2017 7:28pm
