Home > Technical (L322) > More FBH Info
Page 4 of 4 <1234
dan_uk_1984
Genuine LR Kit here:
http://accessories.landrover.com/inter/acc...137AA2E159
Can someone with a TD6 ring a stealer and enquire what year it will work with?
Also, whilst poking around in Dolphinboy's boot I found a small square plug - I would hazzard a guess that this runs from the webasto reciever (not present) to his FBH (present).
So could someone else with a TD6 check if there is a spare wire with a square plug kicking around in the right hand fuse area?
Thanks,
Dan
Post #42095 13th Dec 2010 12:13am
Dolphinboy
dan, I'll get a picture up today of the plug end. And thanks for the other info on the PM. Thumbs Up
Post #42105 13th Dec 2010 8:53am
SteveMFr
Site Sponsor
Veeery late jumping in here.
Dan, the square plug is for the T60 - the earlier telestart by Webasto. I think only the 2002 TD6's had this (could be some 03 as well, tho). The later ones should have the same plug as yours for the T80/90. What year is Dolphinboys RR? Would this be the plug (color doesn't matter)?
The remote looks different too:
As far as the kit goes, when I spoke to Webasto about your remote I also asked about a retrofit kit (Webasto makes this kit for LR as the FBH supplier). I know that this kit works for all TD6's - didn't check on the TDV8's. I'll do that this week, tho as I have to drop by the stealers anyway.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #47094 23rd Jan 2011 1:59pm
Page 4 of 4 <1234
