![]() | Home > Technical (L322) > L322 TDV8 "Key in Ignition" message when removed, |
| alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801
I would do a battery reset first before trying a garage..worth a bash...whites auto services in Edinburgh are great.. |
| Peasemould Member Since: 11 Oct 2016 Location: Scotland Posts: 5
Thanks for the swift response and the recommendation. What do you mean by a battery reset, I couldn't find a procedure in the manual? |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883
the battery reset info is in our wiki, link is at top right of the page... |
Great, thanks. |
Apologies if I'm being a bit dim here but I can only find references in wiki to resetting defect codes on the message centre. I don't ever get Test Nr01 message, after reporting "Control Check OK", it goes to "A/V Off". I'm, of course, not in a position to follow the correct procedure for disconnecting the battery since I cannot turn it off and remove the ignition key for the required 2 minutes since it doesn't acknowledge the removal of the key. |
I received a suggestion that the problem may be something sticking inside the ignition barrel so it didn't acknowledge the removal of the key. I sprayed switch cleaner into the barrel whilst wiggling the key, solvent based not oil based as the latter can leave a sticky residue in such things and ultimately make matters worse. This seemed to work and the system now acknowledges the removal of the key. The pairing procedure with the ignition didn't work until after I'd carried out the procedure with the driver's door to activate the key fob. Then the ignition setup procedure worked and I was able to lock and unlock the car remotely with the fob. All this with the ailing battery recharged. I've a replacement battery ready to go in tomorrow, weather permitting, so I'll report back as to how that goes.
| All times are GMT |
