![]() | Home > Maintenance & Mods (L405) > missing bits. tool kit? |
philbathurst Member Since: 28 Apr 2013 Location: Iver Posts: 143 ![]() ![]() ![]() |
if you have a full size spare wheel there should be a wheel lifting strap kit - this was missing on my new one - took a couple of calls to the dealer to convince him it should be there, they eventually supplied it FOC various other LR's this one is still the best |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 ![]() ![]() ![]() |
I bought the wheel lifting strap kit from Dan @ Duckworths. It is only a few pounds and easy to instal. |
Mariana Black Member Since: 30 Jul 2014 Location: Stockton-on-Tees Posts: 89 ![]() ![]() ![]() |
Sorry the boot needed hoovering out - just got the car.
Nick Ground Member Since: 27 Dec 2011 Location: Dorset Posts: 584 ![]() ![]() ![]() |
Chocks and wheel brace are under the spare wheel.
bear100 Member Since: 22 May 2011 Location: south wales Posts: 204 ![]() ![]() ![]() |
Ahh thanks guys, will have a chat to the dealer tomorrow!
Hi
CUE99T Member Since: 02 Oct 2011 Location: Glasgow Posts: 779 ![]() ![]() |
quick one....the lifter....is it a cable with a red hook on it? I have that but don't know if thats all the lifter is?
I don't know if it's the same on the 405 but the 322 has two straps that attach in the wheel well wall near the back seat, go under the wheel and a long black plastic 'bracket' that slots into the lower tailgate lock.
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 ![]() ![]() |
its different on the L405. One leg of the strap has a hook which goes on to the top of the rear tailgate opening. then a lifting plate on the other leg fits in the centre of the wheel and the remaining strap is pulled to lift the wheel from the well like you were using a block and tackle. Agueroooooooooo. 93-20
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1172 ![]() ![]() ![]() |
The first aid kit is a option. |
Welshhope Member Since: 19 Jan 2015 Location: Cymru Posts: 16 ![]() ![]() |
At a reasonable £35! |
