Home > Technical (L322) > Alternator Belt changing incl. tensioner....
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Dear gentelem, happy 2017, and a question: who knows the steps to change the big alternator belt at 4.4 TDV8 2011 313hp? Thanks a lot! Best rgs, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #421289 5th Jan 2017 5:57pm
this should help,
http://www.fullfatrr.com/forum/topic36064.html
Post #421290 5th Jan 2017 6:04pm
Uli, it's not a really easy job.
You have to remove the fan, the fan shroud and possibly some coolant pipes, as well as having the AC emptied, though I think that it can be done without disconnecting the AC.
Someone (I will look and find) recently changed their alternator which has most of the steps. There is nothing that can't be fixed with a hammer😜😜
Post #421329 5th Jan 2017 9:08pm
Found it...http://www.fullfatrr.com/forum/topic40761....alternator There is nothing that can't be fixed with a hammer😜😜
Post #421330 5th Jan 2017 9:10pm
Meerbusch
Hi guys, thank a lot for your quick answers, good help, so I will bring the car to the official.... it is Clients car, and this work seems not so easy like the changing of the cracked oilcooler in the V (just done), and afterwards I saw the tnesioner and the belt, the belt only runs 80% around on the tensioner, and the belt squeeses also very loud, when I spray Silicon on it, the noise goes away for 20 seconds....,
we will see, my dear gentlemen...... L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #421333 5th Jan 2017 9:16pm
if its running off the tensioner then its possibly the tensioner which is failing. i recall Craig mentioning that a few months back. There is nothing that can't be fixed with a hammer😜😜
Post #421337 5th Jan 2017 9:36pm
Meerbusch
OK, Sir! Have orderd the tensioner at official for monday, will build out the tensioner first, and will clean the belt (because some coolant swaped above him), and will fix. For cleaning the belt you have some ideas? The beast is the black one in waiting Position for Workshop. Best rgs, Uli
Post #421339 5th Jan 2017 10:05pm
something like this, got some for mine which stopped a small squeak, for a while.
https://www.amazon.co.uk/Lorry-Water-Alter...belt+spray
crags post at end of this topic http://www.fullfatrr.com/forum/topic36064....=tensioner There is nothing that can't be fixed with a hammer😜😜
Post #421342 5th Jan 2017 10:26pm
Meerbusch
OK, good product, will buy tomorrow in cars-supply-store. Also I believe good is (german word: HIRSCHTALG), White material for door-gaskets in winter. L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #421344 5th Jan 2017 10:28pm
gummi pfledge is what we have over here.
https://www.amazon.co.uk/s/ref=nb_sb_ss_c_...KFVJIA4DU7 There is nothing that can't be fixed with a hammer😜😜
Post #421346 5th Jan 2017 10:33pm
Meerbusch
Or this, will buy also tomorrow at my shop...
https://www.amazon.co.uk/Tallow-Rubber-Pen...hirschtalg L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #421352 5th Jan 2017 11:20pm
rik
Scotland 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
belt is real easy remove engine tray slacken fan shroud feed new belt around fan and with someone underneath with a leaver feed belt around pulleys and use leaver on tensioner slip belt into place and wala one new belt no fuss exept bolts on tray which there are many good luck
Post #421361 6th Jan 2017 2:29am
Meerbusch
@rik, my english is not so perfect, that I understand your kind response..., but here a picture of the tensioner....
Post #421546 7th Jan 2017 9:06am
Meerbusch
NEW tensioner, old belt, all is 100% perfect, no squezzing, no noises, car runs wonderful, also the oilcooler is perfect, no leaks more! Thanks a lot to all gentlemen here!
(Was my first 4.4 TDV8 in my garage, only 3.0TD6 or 3.6TDV8)
Post #422139 10th Jan 2017 11:03pm
rik
sorry my mistake i thought 4.4 v8 petrol just did mine and it was real easy glad you got it soted
Post #422155 11th Jan 2017 1:38am
