Home > Technical (L322) > 3.6 tdv8 FBH shuts down prematurely
Henrik07
Norway 2007 Range Rover Vogue TDV8 Santorini Black
Hi all,
Car is a 2007 3.6 tdv8 Vogue. I have been trying to use my FBH to preheat the car these last few weeks, both with timer and remote. It generally shuts down after only a few minutes of running, even though it does fire as it should. What could cause this? Does the car monitor battery voltage, shutting down the fbh to make sure there is enough juice left to start the engine? I thought this might be the case, so the other day I left the car on a charger overnight and next morning the fbh worked fine. I thought I'd cracked it, but today, to make sure, I jumpered the car to a known good battery before firing the heater, but again it only ran for a few minutes. I'm confused.
I guess my number one question is whether the system does shut down if it senses battery voltage going low. If there is no such protection, what could be the cause of my problems?
Thanks!
Henrik
Post #421367 6th Jan 2017 7:52am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Hi Henrik, have a read in the wiki on here, under info. It appears the fbh will not work below a certain voltage.
So you need a good battery to start with.
Post #421369 6th Jan 2017 8:25am
SveinHa
Norway 2008 Range Rover Vogue TDV8 Buckingham Blue
My FBH works well when the engine is running but shuts down within a few minutes when engine is off. I haven't done any more checks but I'm pretty sure the water pump in the FBH is seized. When the engine is running, there are sufficient circulation thru the FBH but when the circulation stops, the FBH overheats and then shuts down. "Plentraktoren/Garden tractor": 2008 L322 TDV8
"Project": 1990 90 County 300tdi
Post #421370 6th Jan 2017 8:37am
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Search for Rover 75 - there are links on here to a great diagnostic thread by a FBH expert
Firing, running and the shutting down is usually a seized water circulation pump - this is a secondary pump which is not used when the engine is running 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #421460 6th Jan 2017 5:33pm
GraemeC
This one is a good start, there is also lots of other info Thumbs Up
http://www.the75andztclub.co.uk/forum/showthread.php?t=71982 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #421523 6th Jan 2017 11:25pm
Henrik07
Thanks for the input.
I have been reading all I've been able to come across, but I'm still in the dark. Battery has now been replaced with a new one, but still I only get about 9 minutes before it shuts down. I suppose it could be the aux water pump, but I would expect it to overheat in much less than 9 minutes if the coolant wasn't circulating. Maybe natural convection / siphoning action cases some circulation? It shuts down just as it's starting to blow properly warm air.
Any more tips are most welcome!
Thanks,
Henrik
Post #423118 16th Jan 2017 7:42pm
