Home > Maintenance & Mods (L322) > Iphone 3G/ handfree
Mounty
Switzerland
Iphone 3G/ handfree
I got a vogue and it has from the looks all the buttons/microfones for handfree talking. What is the easiest and cheapest way to speak over my Iphone via bluetooth handfree? Daniel
Past:FFRR 2004 Vogue 4.4l bonnatigrey/sand/ burr walnut
Modifications: SC grill (not fixed) SC MY10 sidevents (not fixed), MY10 Letters front and back, clear sidelights , MY10 rear lights (not fixed), MY09 steering wheel trims, new MY09 sterringwheel 19'' seven spoke wheel (not fixed) 19'' MTS (not fixed), 20 '' wheels, doorhandelcovers brunel (not fixed), complete doorhandels (not fixed) burr walnutdoorsouround (not fixed)
Post #42151 13th Dec 2010 12:52pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
Just activate bluetooth in your iphone (settings/general/bluetooth) and when Land Rover is found enter 2121 and that's it. Mine works flawlessly.
Post #42192 13th Dec 2010 7:23pm
GJOB
2005 Range Rover Vogue SE Td6 Java Black
If you having trouble getting it to always pair to you phone or you want to use the phonebook function then speak to "wiggs" on here who sells an upgrade to the Bluetooth module.
Hope that helps Thumbs Up
Post #42788 19th Dec 2010 5:54pm
pdt
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
just done the job with Wiggs - all i can say it is worth the £60!
Wiggs is a great guy too!
cheers
pdt
Post #42791 19th Dec 2010 6:29pm
SteveMFr
Site Sponsor
Hi Daniel,
Unless you have the BT module, you are not going to get anything to work. The easiest and cheapest method is probably Parrot - if you have an iPhone there is a new Dension unit for both BT and iPod over the factory nav sytem for about €250.
If you want to do OEM, you'll need a BT module (BMW ULF), microphone, BT antenna, and a pairing button. All in all around €500. But by far the best solution.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #43137 22nd Dec 2010 9:58am
SteveMFr
Site Sponsor
It's a pre touch screen (04) RR. Not that easy.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #43138 22nd Dec 2010 9:59am
Mounty
Switzerland
So I can confirm Sad and I got a Iphone
Steve you got a pm Smile Daniel
Post #43208 22nd Dec 2010 6:29pm
Mounty
Switzerland
Got probably the BT Box but in doesn't find it. I have a sliver box (BT Module?) and and a blackbox (TV?) underneath the satnav? What do I do now? Daniel
Post #43653 27th Dec 2010 9:57am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Hi.
The Bluetooth module should be a small black box about an inch thick on the top of the sat nav held on with a screw through the centre.(if it's Nokia)
Don't suppose anyone with Microcat could check your VIN for the build sheet to ensure you have PTI/Bluetooth?
Edit http://gallery.me.com/stephen.wood125/100003/Nokia%20BT%20Module
Post #43685 27th Dec 2010 2:17pm
SteveMFr
Site Sponsor
Only on the later RR's with touch screen navs, happy. Daniel has an earlier RR.
The BT module would normally be mounted vertically at the LF of the elecronics compartment. (couldn't find a pic with the BT module installed)
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #43770 28th Dec 2010 11:46am
Stephen.125
Ah ok, thanks Steve- I stand corrected. Sorry Dan, my mistake!
Post #43771 28th Dec 2010 12:17pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
I had the parrot system in my 1st RRSport TDv6SE, it was installed by the local LR dealer and it was so simple to operate, paired first time every time and just worked well. On the basis of that when I needed a new radio fitted in my Defender I thought I might as well get one with integrated BT and again went for the latest Parrot integrated radio/mp3 player/BT phone system - as a hands free it is excellent, it pairs 1st time every time and will play my ipod files on the BT as well BUT as soon as I connect it up to the cable connection and put the phone into the slot behind the faceplate radio reception gets continuous pulsing interference from the iphone, the iphone gets very warm in the slot even though it is vented and i loose the GPS function of the iphone as I cannot seen the phone with the control screen/ cover on the unit if I want to listen to my music or the radio. It's a good system despite that. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #43787 28th Dec 2010 3:34pm
