Home > Off Topic > ifor williams tri axle trailer
builder1966
England 2004 Range Rover Vogue Td6 Adriatic Blue
hi just bought a ifor Williams tb5521-353 tri axle trailer has any one got a ifor Williams trailer ? I've been looking at fitting a caravan remote mover to it to get into tight spots any one tried fitting one to a trailer before any ideas welcomed
Post #421583 7th Jan 2017 12:44pm
It's not a bad idea and I'm sure it would be doable. It would need to be a chunky one though as slewing a triaxle would take a lot of welly, so you would need a 4 wheel set up.
Also you would need onboard power and a 12s socket to charge the battery from. There is nothing that can't be fixed with a hammer😜😜
Post #421609 7th Jan 2017 3:21pm
mzplcg
If twin axle caravan version is anything to go by I can do way better using the car and in half the time too. Personally I wouldn't waste money on it. If anything look at one of those removable front towballs for shunting.
Post #421619 7th Jan 2017 4:12pm
builder1966
front towballs are pants its just to move it into the barn when its being stored it has a battery onboard as it has a tipper and winch on board so power isn't a problem been looking at the easymove v4 spoke to dealer in usa earlier reckons it will be fine hes going to talk to technical dept and call back on Monday cheers for input
Post #421654 7th Jan 2017 7:59pm
3528cc
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
I have a tri axle Graham Edwards, I find it easy to move (unladen) Is possible if required to jack up the jocky wheel and take the weight off the front / centre axle, making it really easy to manoeuvre, I have a smooth shed floor though Wink Regards
Royston
2008 4.2 Supercharged Autobiography
1994 Classic Vogue SE
1999 Rover BRM
1987 Rover Vitesse Twin Plenum
Post #421659 7th Jan 2017 9:03pm
builder1966
the floor in barn is as smooth as babys bum was only rebuilt 4 months ago the bed of trailer is 18 foot just need a little help to move as not possible o reverse a high top van in to push it also it will be laden when in there
Post #421665 7th Jan 2017 9:27pm
If you wind the jockey up to full does it lift the front 2 sets of wheels? On my twin axle Indespension winding the jockey to its max will lift the front axle. If it does then you may get away with winding it out when maneuvering and only needing a mover on the rear axle. There is nothing that can't be fixed with a hammer😜😜
Post #421671 7th Jan 2017 10:05pm
builder1966
can get the front set off the ground with a jack may put 2 jockey wheels on and get the mover on rear axle hopefully I can get it too the back of the barn its a straight run cheers for the ideas
Post #421674 7th Jan 2017 10:14pm
3528cc
I suppose it depends on the load carried, what are movers rated at, forgot to mention my trailer is on 10" wheels Regards
Royston
1999 Rover BRM
Post #421680 7th Jan 2017 11:03pm
builder1966
movers good for up too 7750 lb but guy said they will be having a new model out in febuary up to 12500lb should do the job
Post #421684 7th Jan 2017 11:27pm
