Home > Technical (L322) > Stalled after water on road!!!
Your fault is possibly nothing to do with water, when did you last change the fuel filter?
Post #421232 5th Jan 2017 12:21pm
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Fuel Fiter was changed recently 2-3k km ago.
But it stalled right after going in water on the highway entry at high speed.
It was pretty deep and two weeks ago.
Still stalls on the road.Pretty dangerous.
Post #422016 10th Jan 2017 12:33am
umitbat
Today it stalled again.
First it didnt feed fuel when i accelareted uphill;then it stalled after mostly 1km.
After sitting 1-2 minutes it started again.
It does this even full or empty tank time to time.
Post #422069 10th Jan 2017 4:14pm
cass
Have you changed the fuel pump yet?
It seems like the most likely problem - if you have and the problem is still there you could try slackening the fuel filler cap in case the tank vent is blocked?
It's not very likely but costs nothing to try it
Post #422075 10th Jan 2017 5:16pm
umitbat
No i di not change yet.
Will try cap;)
Do u think the pump in the tank is the problem?
Post #422077 10th Jan 2017 5:25pm
cass
As the others have said it sounds like your low pressure pump is at fault so the problem will not go away until you change the pump.
Post #422130 10th Jan 2017 9:33pm
umitbat
So not the one in the tank i guess.
Post #422140 10th Jan 2017 11:09pm
umitbat
The pump in the tank was faulty.
Maneged to change only the pump.
Hope its fixed!!;=)
Post #422249 11th Jan 2017 8:56pm
umitbat
To give some useful info if your car stalls time to tim after some loss of power,in-tank pump faulty not front pump.
Anyway i still cant figure why it stalled after water first...
Post #422381 12th Jan 2017 2:13pm
