![]() | Home > Technical (L322) > Rear Doors sometimes fail to open |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8719 ![]() ![]() ![]() |
Cheapest option is to sell the kids.... |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3241 ![]() ![]() ![]() |
Deffo bcm. You may find that it stops working via the central dash button later. As a short term measure try spraying some lube down the pin hole in the top of the door card. |
Simran0211 Member Since: 10 Jun 2016 Location: Coventry Posts: 300 ![]() ![]() ![]() |
The first one appears not to go down well with the wife option 2 I will give it a go in the morning 😆👍 |
Done option 2 and all seems well it seems to have done the trick thanks for your advice |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
Was it the bcm? How did you fix it? |
