![]() | Home > Technical (L322) > Air suspension in active |
D34NO Member Since: 21 Jul 2016 Location: Lincoln Posts: 46 ![]() ![]() ![]() |
Hi all, i drove home this evening and this message popped up 'Air suspension inactive' also i noticed the light on the dial in the cab is unlit, upon reaching home i got out and saw that the front has dropped but the rear is up, so my wagon looks like a cross between a dragster and a monster truck!! there is also a ticking and high pitched sort of whistling/tapping noise from under the engine which someone said could be alternator related, i have also washed my car earlier with a Karcher. just mentioning all these things due to reading a few threads and there seems to be some similarities. ive tried the lock to lock but nothing, hence im writing this. the Gap iiD tool seems to be a popular choice in figuring this out but i need to know first ifits gonna just be a case of spending a few pennies on parts to fix it or the diagnostic will sort it out first.
yeah im beginning to think this iiD tool is a good option, so if ive read correctly a hard fault can be rectified by disconnecting the battery for a long time say over night? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
It never worked for me but my compressor had lost the will exhale. |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
I'm a little confused. You do appear to have a hard fault which requires clearing with the iiD tool or the like.
there is no light on the actual control knob and also there is no light on the light panel next to it which usually indicate what height the vehicle is at. |
Thanks that is clearer now. |
guess i best starting looking around to find one of these tools then |
Pm duckworths mate for a price.. recommend the Bluetooth version.. |
Ordered iiD tool this morning hopefully this will help out |
OK so my iiD tool turned up this morning,(thank you Duckworths) got it all set up and initial scan had 51 faults! |
