![]() | Home > Maintenance & Mods (L322) > 2003 - Air susp Inactive, clean sensors? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Have you tried the full lock to opposite full lock and back... this should reset the EAS and clear the screen of doom |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 766 ![]() ![]() ![]() |
Sorry for the late reply Miggit, had loads on at home and only had a chance to sit back down. Yep, tried the lock to lock but nothing, fault still there.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
Might be worth trying http://bagpipingandy.com/compressor.html
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
Along with the piston ring kit mentioned above I would change the air drier granules.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8715 ![]() ![]() ![]() |
Best thing to do before spending money is ask the guy who cleared the faults, what the fault was, if you know which part of the system is at fault then it saves just chucking money at it, it could be a height sensor, a valve block and quite a few other things as well as the compressor... |
You may get away with putting the granules in the oven, I certainly hoped I could.
Fair point, I'm a northerner now so like the "cheap" route... mine were pretty white and looked fine, maybe they had been replaced in the past... |
Thanks all, am going to have a go at refurbing it myself with the kit, errrrr where do the drying granules go please? (never pulled one apart so no idea I'm afraid)
Very obvious when you get it apart, be careful, if they are dry they are nearly lighter than air and go everywhere with the slightest breeze..... |
WABCO drier granules replacement video |
Thanks everyone, so would you go down the repair it route first? Watched a video and it said buying a new compressor everything in it is new, where as repairing it only the piston ring and seals are new.
There's something reassuringly reassuring about a northerner working on t'car ![]() |
Stormin Member Since: 22 Feb 2012 Location: West Yorkshire Posts: 266 ![]() ![]() |
Had the same on my old one, new compressor, still not cured.
Interesting Stormin, is the tank something you can see just by laying under the car? (thought I'd check if its an easy thing to eliminate)
