Home > Technical (L322) > 2009 RR g/box issue |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
RRPhil is the chap to talk too, but I think that is the sort of issues that can be cured by a power flush of the gearbox.. Maybe specialist gearbox help is needed.. a normal garage is no good for these sorts of complaints Yesterday I couldn't spell Engineer... Today I are one!
15th Jan 2017 7:37pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
That era RR has the 6hp26 with the softer lead free stator bush. Ive read filings contaminate the tranny fluid and prematurely cause wear. Unless it's had a very early tranny service (say 30-40k miles) replacing the fluid will be a waste of money. ______________________________
15th Jan 2017 9:32pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 911 |
As rar110 has stated, there was an issue on some 6HP26 models with wear in the rear stator bush which allows the E-clutch circuit to leak and lose pressure causing the clutch to slip. However the E-clutch is only used in 4th, 5th & 6th gears so that sounds unlikely to be the issue here.
16th Jan 2017 12:25pm |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1194 |
I took him up to neil smith this morn and he tested it and said torque converter was slipping very very slightly but not to worry as it was minimal until it got worse, and it wouldnt damage any other parts of the box, usually its the carbon build up he said but overall quoted him 1100+vat for a reman converter gaskets filters oil etc, but would you try the eds6 valve first stil? thanks _____________________________________________________
16th Jan 2017 2:18pm |
