![]() | Home > Technical (L322) > Are my parking sensors goosed?? |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 798 ![]() ![]() ![]() |
I am hesitant to call this an 'issue' but I am also aware that I've had nearly two years of perfect motoring in the TDV8 so it's time something started to give....... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
snow, ice, and water play havoc with the parking sensors , i would say that its one or the other..test each sensor by listening to each one and if you hear a clicking then that sensor is working, if not try to dry it using a hair dryer.. ... - .- -.
Like ^he^ says moisture in the small black circle which freezes interferes with the ultrasonics. Mine have been a bit hit and miss since the cold snap. Warmth sees them work OK. |
@ stevegt - many thanks for that extract. But what's an owners manual? |
I have seen similar on a friends L322 and I had no idea what was wrong. |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1528 ![]() ![]() |
Not that it helps but mine is at the dealers with this at the moment. (as well as a leaky rear diff)
when i brought mine the rears didnt work and this was down to broken wires on the off side which i was told is a common problem, wires mended and all working well since. ... - .- -.
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
Suffered the same problem with the RRSport sensors in wintery weather - road salt seems to have a detrimental effect on them too 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3807 ![]() ![]() |
can also be a short in the system, mine went like that when a cable broke |
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 ![]() ![]() ![]() |
From the workshop manual:
Thank-you for this Steve. However, I have some interesting news which doesn't concur with the above....... ![]() Yesterday, (ambient temp above freezing) I selected reverse and everything worked as normal. Tested both front and rear sensors with success! Methinks 'something' doesn't like the cold...... ![]() ![]() |
Posting from +32c Malaysia ............................... JMC could you have had any water freeze over any or one of the sensors or a lot of road dirt taht has been washed off by you 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
Nothing in front of them Tim. Sensors have all been clean / ice-free when this problem occurred. |
you are probably getting water inside the sensor, my son has just had this problem with his bmw sensor.. ... - .- -.
