|  | Home > Maintenance & Mods (L322) > 4.4 M62 lambda control adaption faults, won't go closed loop |
| lee37Vernon Member Since: 12 Oct 2014 Location: Aldershot Posts: 74      | I should also say it would appear on the surface to be running absolutely fine. 2003 4.4 Adriatic Blue FF | ||
|  14th Jan 2017 1:23pm |
| Rewmer Member Since: 14 Jan 2013 Location: Essex Posts: 142    | The o2 upstream sensors should be reading between 0v and .8 cycling every second or so on idle when warm. Rears should stay a steady .45 v. A MAF reading would help. Look for approx 22kgs hr on idle with loads off No7 - 2003 V8 Vogue | ||
|  14th Jan 2017 2:50pm |
| lee37Vernon Member Since: 12 Oct 2014 Location: Aldershot Posts: 74      | Thanks.
|  15th Jan 2017 8:58pm |
| doclees Member Since: 24 Jun 2015 Location: PA Posts: 672      | I have similar issues but have done the PVC valve and hoses yet. Interested to see how this turns out. | ||
|  16th Jan 2017 4:09am |
| Rewmer Member Since: 14 Jan 2013 Location: Essex Posts: 142    | Here you go. I had a dig around and found these known good MAF values from when I was diagnosing a miss fire..
|  16th Jan 2017 6:53am |
| lee37Vernon Member Since: 12 Oct 2014 Location: Aldershot Posts: 74      | I'm getting roughly from yesterday's check
|  16th Jan 2017 7:14am |
| ohuntsman Member Since: 21 Mar 2016 Location: Cornwall Posts: 341      | I'm getting the very same fault - we live in Farnborough, it must be the air!
|  16th Jan 2017 5:48pm |
| Rewmer Member Since: 14 Jan 2013 Location: Essex Posts: 142    | Dont buy cheap. No7 - 2003 V8 Vogue | ||
|  16th Jan 2017 6:10pm |
| lee37Vernon Member Since: 12 Oct 2014 Location: Aldershot Posts: 74      | 73+ vat off my mate at CAF  | ||
|  16th Jan 2017 6:28pm |
| ohuntsman Member Since: 21 Mar 2016 Location: Cornwall Posts: 341      | Let me know how you get on, or it is definitely the air.... | ||
|  16th Jan 2017 6:37pm |
| holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086      | I bought the Bosch MAF from Eurocarparts as if I applied a light throttle up to around 1000-1200 rpm the engine would hunt up and down considerably and with the new MAF it is great.
|  17th Jan 2017 7:41am |
| lee37Vernon Member Since: 12 Oct 2014 Location: Aldershot Posts: 74      | Thanks for that. That's Exactly what mines doing at the moment..
|  17th Jan 2017 8:07am |
| holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086      | I cleaned my MAF last year and it made some difference, the MAF may not be the complete cure but you need to know it is working 100% to be able to diagnose any other issues | ||
|  17th Jan 2017 8:20am |
| lee37Vernon Member Since: 12 Oct 2014 Location: Aldershot Posts: 74      | New Maf giving essentially the same readings as my old one. Still hunts when you try and hold low revs around 1000rpm.
|  17th Jan 2017 5:00pm |
| Posting Rules
