Home > Technical (L322) > Engine bay noise
alistairh
Engine bay noise
Just a quick post but I've just noticed everytime I put the key in the ignition( not starting car) I'm getting a high pitch whine from what sounds like the area behind the front grill? Cannot pinpoint it but it's the first time Ive noticed tbh.. nothing's running on car and I'm wondering if it's something electrical.. going to have a good poke about at the weekend just wondering if anybody else has this on the petrol v8?
Post #423431 18th Jan 2017 9:36am
sounds normal, unless the noise is very loud..
Post #423442 18th Jan 2017 10:10am
alistairh
It's not overly loud. Never noticed it before so it kind of threw me.
Post #423444 18th Jan 2017 10:14am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Could be the cooling fan insidd the ecu box.
Post #423473 18th Jan 2017 12:08pm
alistairh
Seems to have gotten louder.. it only starts when the keys in position 2? Sounds like its coming from the front of the engine? No errors being read by iid (yet Laughing
Post #423834 19th Jan 2017 8:10pm
holidaychicken
Have you listened next to the big black box at the left hand side of the engine bay looking from the front as these fans can fail?
Do you have your heater turned off as there is a coolant pump on the nearside inner wing next to the heater valve?
maybe the aircon condenser fan is having a funny turn..
Post #423872 19th Jan 2017 11:25pm
alistairh
Hi mate. All quiet in the ecu box and heatings off.! It sounds like it's coming from within the engine, possibly the throttle body? Shall get a better look/listen in the daylight.. Thumbs Up
Post #423875 19th Jan 2017 11:53pm
alistairh
Found a few of these on BMW forums relating to the throttle body as well.. will check it out after work..sounds similar..
Post #423894 20th Jan 2017 7:40am
holidaychicken
That's weird !
Post #423898 20th Jan 2017 8:31am
alistairh
I was correct .. unplugged this and noise stopped..I can hear what sounds like the throttle body opening and this annoying whine which has gotten louder..my idle under 1000rpm is still slightly unstable, I wonder if it's linked??
Post #423981 20th Jan 2017 5:06pm
holidaychicken
Seems like it may be normal, think this thread is linking to the same engine.
http://www.bimmerforums.com/forum/showthre...itch-noise
If you have rough idle it could be many things as well s the throttle body, MAF, air leak, coils , plugs, o2 sensor maybe, diagnostics would hopefully point you in the right direction.
My faultmate can tell me which cylinders are running rough if any which you may get on other diagnostics as well as air leakage and all sorts of other things that i don't really understand
Post #424005 20th Jan 2017 6:19pm
alistairh
That's the thread I've been reading Laughing at least with the m62 you have the option of posting on both land rover and BMW forums to trouble shoot lol..I've got new plugs to fit shortly then will check the coil packs at the same time.. maf and o2 readings are within range so hopefully nail it shortly... it still pulls like a train and drives great so not the end of the world.. cheers for input buddy..Thumbs Up
Post #424019 20th Jan 2017 8:31pm
holidaychicken
yep definitely useful sharing the mechanicals with the Bimmer crowd, they are even more nuts than RR owners (maybe) and dhon't shy away from getting the spanners out Smile
Post #424024 20th Jan 2017 8:51pm
