![]() | Home > Technical (L322) > ticking noise inside cabin |
iancollins Member Since: 17 Mar 2010 Location: milton keynes Posts: 264 ![]() ![]() ![]() |
does anyone know what the ticking noise (sounds like a clock ticking) is coming from inside the car.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35859 ![]() ![]() |
nobody knows ian.... |
Do you have a diesel (helps to know... |
he does have a diesel steve, hover mouse over little car in avatar area and all will be revealed... ... - .- -.
ahhh haha |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 884 ![]() ![]() ![]() |
Mine does the 1 second tick too while the FBH works and I have a wooing noise while it's on too... |
The mini jet engine sound is normal (RR owners are supposed to be so used to that from their Lear jets that they don't notice it |
Actually the ticking only lasts 10-15 seconds at the beginning. It did this from the first day I had it. |
Mine doesnt do this |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
My 2005 X5 had an electro-magnetic fuel pump for the webasto, this was silent. Have the fbh fuel pumps been changed for the newer model FFRR? Ian |
No, they are still the same. The pump actually meters the amount of fuel, and by varying the frequency, the mixture can be changed (petrol and diesel actually share most components - the ecu has a different frequency for pumping one vs. the other).
Sportex Member Since: 12 Jun 2010 Location: Up North Posts: 366 ![]() ![]() ![]() |
mine does this, like the ticking of a clock! also when first moving sounds like a fan struggling to work properly??? No body told me there would be days like these
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 ![]() ![]() ![]() |
mine ticks all the time its on until the engine is up to normal temp.
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
Sportex, both the TDv6 RRS and the TD6 FFRR I had did that fan running bit for the first 1/4 mile or so, I was told it was something to do with the gearbox oil cooling or the Viscuous Coupling cooling sensor - nothing to worry about. Neither the RRS TDv8 nor my current TDV8FFRR do it though. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
