![]() | Home > Technical (L322) > STEERING ANGLE SENSOR |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8807 ![]() ![]() ![]() |
First thing is to get it checked with diagnostics, you can get live info from it to see if it is working, changing it means removing the upper steering column from the joint just the engine side of the bulkhead, you then remove the lower part of the column and change the sensor, it's like a donut and encircles the column, it's a bit of a faf to do and it helps if you have someone to help getting it back on, pushing the column from inside the car and lining it up from under the bonnet is a bit difficult on your own.... Download Rave from the WIKI it tells all... If some |
Simran0211 Member Since: 10 Jun 2016 Location: Coventry Posts: 300 ![]() ![]() ![]() |
Oh my God 😩 |
He's just showing off |
Bluegreygreen Rangie Member Since: 10 Aug 2012 Location: Australia Posts: 53 ![]() ![]() |
Dont' be put off by the picture, you don't have to remove a single dash component. You need a tool like the Gap to re set (calibrate or re set from memory) the new one though before it will work
Cheers Dave |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 325 ![]() ![]() ![]() |
Also could be one of the ABS sensors. Changing Steering agle sensor is 30 minutes under the bonnet, perhaps at the steering sensor you have only to Change the black ring..., so you have not to learn it. Best rgs, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
