![]() | Home > Maintenance & Mods (L322) > Low Coolant Temperature + Current Drain |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3986 ![]() ![]() ![]() |
Welcome, |
Gary Williams Member Since: 17 Jan 2017 Location: Essex Posts: 65 ![]() ![]() ![]() |
Hi NiceDayForIt,
No, I haven't found the EGR thermostat. Where is it? The manual shows it at the top of the radiator but I can't see it. I'll check I have the correct manual!
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6431 ![]() ![]() |
Here it is, just remove top front engine cover by the radiator and all will be revealed:
Hi Joe90,
from RAVE
Hi Joe90,
Dave 67 Member Since: 11 Dec 2016 Location: Oxfordshire Posts: 34 ![]() ![]() ![]() |
When I had the egr thermostat issue on my bm it ran up to temp ok on the motorway but dropped down to just above the first line on the stat when running in stop, start traffic or plodding around the back roads.
