![]() | Home > Technical (L322) > TDV8 Injector/Leak off Pipe Diesel Leak. |
lazylabs Member Since: 01 Nov 2016 Location: Lincoln Posts: 78 ![]() ![]() ![]() |
Evening,
Answered it myself |
Kidsathart Member Since: 02 Nov 2020 Location: Essex Posts: 2 ![]() ![]() ![]() |
Hi just bought this amazing car
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 492 ![]() ![]() ![]() |
It should come out if the plenum chamber is out (the box that holds the cabin filter)
Thanks for your reply, I had removed the filter chamber and aircon pipe was just jamming it, it became a case of very carefully springing the pipe and it finally came out.
Landmark Member Since: 22 Nov 2020 Location: Hampshire Posts: 118 ![]() ![]() ![]() |
Would you happen to have number for o rings or size spec please. |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 670 ![]() ![]() ![]() |
LR019118 is what we used, I would double check it though as always |
Brilliant many thanks. Getting ready to remove manifold. |
OK, update i have removed all bolts from plastic manifold on drivers side removed injectors but seems to be a clamp hooked over stud. just when i though acces was bad enough on injectors etc. Does this come off? |
Mikeerhymes Member Since: 01 Sep 2018 Location: Manchester Posts: 29 ![]() ![]() ![]() |
Has anyone given this a go on the L405? The pipe has worn and sprung a leak, I assume something was rubbing.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1014 ![]() ![]() ![]() |
I had the foam insulator stuff disintegrate on me, so had to buy the part from main dealer
Thanks, sorry it might not have been clear, I just wondered if anyone had tips for removing the insulating foam as it looks a right challenge! |
For anyone else, it is those bolts (5 of) which are a serious PITA to remove on the L405, not sure if it’s easier on the L322!? LR022590 leak off pipe is what I’ve fitted due to a wear split on the crossover section, very frustrating that this appears to be accidental wear & tear 🤬 Photo of the driver side parts just in case it helps anyone:
