Home > Technical (L322) > Judder when braking
DavidS
Spain 2007 Range Rover Vogue SE TDV8 Java Black
Agreed
Post #423707 19th Jan 2017 11:31am
Rich86
United Kingdom 2009 Range Rover Vogue TDV8 Nara Bronze
I had juddering when braking over 50mph and it was discs so I replaced with genuine discs and pads and it was sorted. 2009 Vogue TDV8 Nara Bronze
2002 Vogue V8 Zambezi Silver
1986 90 Pick up Deep Bronze Green
1978 Series III SWB Deep Bronze Green
Post #423839 19th Jan 2017 8:44pm
check the rears for sticking calipers, the symptom is pretty hard to pin down, could be bushes, could be fronts, could be rears. If it was doing it before you changed the discs then i would check the rear end for hot discs after a run. They are notorious for sticking. sometimes caused by the pads sticking in the caliper carrier, sometimes by the actual caliper. First job is to get the carrier off clean off the rust and corrosion where the pads sit and fit some new pads and re build making sure that the pads are not tight where they sit. There is nothing that can't be fixed with a hammer😜😜
Post #423842 19th Jan 2017 8:56pm
ipwn
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
Had this issue, rear caliper sticking.
Post #423888 20th Jan 2017 1:10am
DavidS
Thanks Guys, Sounds like a big session checking everything.
Post #423899 20th Jan 2017 9:29am
