Home > Maintenance & Mods (L322) > Alignment price after rear top bush change.
Boydonegood
United Kingdom 2004 Range Rover Vogue Td6 Ipanema Sand
Hi all
Just so I know I'm in the right price area.
Based in Gravesend/Rainham (Essex). Have just changed both side front struts and both side rear top bushes (well worn!)
I've got lots of wear on inside rear tyres and outside front tyres. Marked up and put everything back to where it was but obviously going to get the 2004 l322 4 wheel aligned and camber done.
Elites in Rainham (who I rate loads) are quoting £69.99 alignment and £19 per wheel for camber.
Price in the right area?
Thanks
Tel Accept, some days your the pigeon, some days your the statue!
Post #423947 20th Jan 2017 3:27pm
its circa £100 for a hunters alignment so that sounds about right...
Post #423949 20th Jan 2017 3:41pm
Boydonegood
Cheers Stan your a diamond!
Guessing £70 for alignment + £40 (rears only an I correct?) + vat £132 so yeah will get it in there!
Thank you Accept, some days your the pigeon, some days your the statue!
Post #423951 20th Jan 2017 3:51pm
cass
Kwikfit did have an offer of £100 to include any more alignments that you need for 2 years. Probably worth doing if you have a local Kwikfit that has the Hunter gear (if the offer is still running).
Post #423956 20th Jan 2017 4:08pm
Boydonegood
Thanks! Other half rung Kwikfit while I was out. "£49 for Hunters alignment but £99 for something about some adjustments for 2 years!"
I'm kinda guessing by that it means they will 4 wheel align and rear camber? Then I suppose if I need to do the bottom bushes within the 2 years I'm covered! Accept, some days your the pigeon, some days your the statue!
Post #423982 20th Jan 2017 5:06pm
