![]() | Home > Technical (L322) > LPFP L322 td6 |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Did you let the fuel run a bit low before filling up?. Below quarter tank, these ff's can suck up some crap out of the tank.
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 327 ![]() ![]() ![]() |
Changed the filter and after a bit of coaxing it started. stopped, started, stopped,started and got it running.
Update.
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
Seems intank pump is faulty.
Well I finally got my beast back.
Was about to say I change my fuel filter every service as the cost of it is pretty small here, albeit I do 6k services FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Trewy1 Member Since: 11 Dec 2017 Location: Bedfordshire Posts: 2 ![]() ![]() ![]() |
I got a problem starting my td6 I can get it running with easy start it will run properly until I give it a good boot it will loose power and once I turned it off it will not start again can anyone point in the right direction |
High pressure pump is dead I bet.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3666 ![]() ![]() |
When I had the doesn't want to start symptoms it was 2 knackered injectors |
