![]() | Home > Maintenance & Mods (L405) > Thule Roofbars on a FFRR?? |
w8pmc Member Since: 30 Oct 2016 Location: West Lancashire Posts: 229 ![]() ![]() ![]() |
How do you fix Thule Roofbars to a MY17 FFRR?
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8064 ![]() ![]() ![]() |
I looked into this and couldn't find any roof bar system for the L405 except for the permanent rails.
le25dse Member Since: 15 Jan 2012 Location: Oslo Posts: 78 ![]() ![]() ![]() |
You are correct. You need the rails to attach cross bars or roof box. The rails for L405 are however prettier than on the L322 so they look nice even when you drive around without anything on them. Attaching the cross bars are also much quicker thing to do with the new system, so I take the cross bars on and off when I need them. On the L322 it took almost half an hour attach/remove the cross bars. ----------
Thanks. I didn't spec a towbar as have nothing to tow & not a fan of the 'hang out the back' cycle carriers so was hoping i could pop the bike/s on the roof. Saying that & in hindsight, the wife's Volvo XC60 can take my current Thule setup & even has the same fixing kit as the BMW F10, albeit the base kit was different so i could use her car or given it would only likely be me & 1 PAX when i go cycling, i'm sure the back will have enough room with the seats folded down to take 2 bikes? Another thing i can't find is a boot cover. Again in the XC60 you get a waterproof sheet that fixes correctly to various points in the boot so carrying a dog, rubbish for the tip or any other less than clean items is a doddle. I can find a rubber tray of the FFRR but that doesn't cover the rear of the back seats or the sides of the boot. Are these available either from LR or aftermarket? |
CMJ Member Since: 10 Oct 2010 Location: Lancashire Posts: 208 ![]() ![]() |
Would be interested in a boot cover also. Have installed the ridged tray for every day but took some old furniture to the tip yesterday and spent ages covering all the leather bits with old sheets. Also felt very guilty filling a 100k + car with tip rubbish. Never bothered with any of our earlier FFRR. Strange. NB Also in west lancs. NR Pesto. 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream |
My order of preference is also - in the car, on the roof, on the back.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
Quick search of "Range Rover boot cover" revealed this (among others) http://www.hatchbag.co.uk/land-rover-range-rover-2013on and http://www.ukcustomcovers.com/custom-boot-liners/land-rover John
I did spot that one & i think we've used them before when we had a Q5. Only issue is to cover the sides etc. it appears with this aftermarket one you have several separate parts to cover the sides & boot entry point so would have preferred on OEM solution ideally.
I'm in Wrightington, so perhaps a local meet could be in order? ![]() |
Range Rover LSE Member Since: 15 Jul 2012 Location: Preston Posts: 47 ![]() ![]() |
I had one from Hatchbag a few years ago on my L322 and found them to be of a high quality both in terms of the material used but also in the fit and finish of them. Range Rover LWB HSE L460
Thanks. I've ordered one off eBay from a Company called UK Custom Covers.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1419 ![]() ![]() ![]() |
I have LR accessory seat covers plus LR accessory load space liner. That deals with most situations, though I do have a trailer to take things to the dump if required. If I have exceptional items to carry I have a tarpaulin that can be spread over the area likely to get wet/dirty. Assuming your dump allows trailers (some differentiate between single and multi-axle) and you have a towbar they are not that expensive to hire, so that might be a better solution than buying seat covers and loadspace liners. Only Range Rovers since 1988 |
JamesD Member Since: 21 Jan 2013 Location: Worcestershire Posts: 203 ![]() ![]() ![]() |
I would be interested how you find this, let us know. 2021 L405 Vogue D300 2016 L405 Vogue 3.0TDV6 (Sold) |
martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256 ![]() ![]() ![]() |
I have a tailgate cover on my L405 from these people
