Home > Maintenance & Mods (L322) > Oil Fill
fatbob
Germany 2011 Range Rover Vogue 4.4 V8 Bournville
Oil Fill
Let me start by saying this f*cking car will be the death of me.
I posted a couple of days ago a slight oil leak, was pointed to a post, ordered o rings and kept an eye on the oil level.
Today I went out for a 20km drive stopped left the engine alone for 10 mins and checked the oil... Underfilled in the red. Drove it home and re ran the check. Same results
Went to the garage bought 1ltr of oil poured it in. Went for the same drive repeated the check...Overfilled in the red at the other end of the guage.
Can anyone give me any advice should I continue to drive it or take it to the dealer to get the excess oil removed?
Post #424342 22nd Jan 2017 10:57pm
bishbosh10
Rings very true - had the same issue this weekend. From a bit of searching it appears that the gauge is extremely sensitive to the car being absolutely level. I tested this with a slight gradient - nose up over filled, nose down 3/4 filled!
I am not burning any oil and still have a slight leak so will will monitor consumption until she goes in to be serviced when I'll get the leak fixed too. Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #424344 22nd Jan 2017 11:06pm
fatbob
Don't know what was wrong with having a dipstick to be honest Smile
Now with this one you have to get the engine up to temperature wait for it to cool down just the right amount, dance around the car clockwise 3 times, put the left blinker on twice and open the boot to a 35° angle whilst whistling the British national anthem you can then get into the service menu to check he oil Smile
Post #424346 22nd Jan 2017 11:11pm
There is a service method to get it to show you the level without waiting......
But it's a secret Rolling with laughter There is nothing that can't be fixed with a hammer😜😜
Post #424350 22nd Jan 2017 11:24pm
fatbob
Please share the RR secrets Smile
Post #424353 22nd Jan 2017 11:41pm
http://www.fullfatrr.com/forum/topic40450....eck+cheque There is nothing that can't be fixed with a hammer😜😜
Post #424360 23rd Jan 2017 12:26am
CS
I recall the handbook saying that it was bad for the car to run overfilled, so if I were you I would check the level again and have any excess removed if necessary. Bishbosh is absolutely right that the sensor is very sensitive to the level of the car and it seems to display in whole units rather than showing the level between lines, so exaggerating the effect. Only Range Rovers since 1988
Post #424417 23rd Jan 2017 2:51pm
