![]() | Home > Technical (L322) > A few Questions regarding my L322 Td6 |
Paul1234002 Member Since: 06 Oct 2015 Location: Manchester Posts: 32 ![]() ![]() ![]() |
I have fitted a new EGR Valve December 2016 and when i turned the engine over there was a droning sound resonating down what seems to be the exhaust. Is this right? Is there something I have missed. This happens now every time i start the car.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
Might be the Fuel Burning Heater kicking in when you start up? The FBH was standard on the TD6. John
Thanks for the reply.
Wouldn't seem to be the FBH then. Are you sure all the connections for the EGR are in place and tight? John
Yes it was only four bolts to the inlet Manifold and to Jubilee Clips and all tight |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7966 ![]() ![]() ![]() |
I blanked mine off when I had a td6.... never had an issue and much better......
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
I think blanking off the EGR will help the turbo to live longer too, as the variable vanes won't gunge up so easily. |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Did you blank the vacuum pipe off ?. |
Blanking the EGR. Did this not throw any faults? |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
yes _____________________________________________________ Zambezi silver Vogue Se unique ![]() |
nope it doesnt _____________________________________________________ Zambezi silver Vogue Se unique ![]() |
Gentlemen,
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 ![]() ![]() ![]() |
I assume that's on the Vogue and above models and not on all the TD6 models? |
