![]() | Home > Technical (L322) > Folding Mirrors |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
Is there a way to change the programming so the mirrors only unfold when the engine is started? Seems a waste of effort having them unfold each time you unlock the doors, after all, you don't really need them until the engine is running do you? Unless you are doing some sort of clandestine work maybe......? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
no there isn't but you can switch it off and go 'manual' ... |
1959terry Member Since: 28 Apr 2014 Location: London Posts: 128 ![]() ![]() ![]() |
Is the auto fold only on later models or do I need to program? Mine is a 2008
MrSkill Member Since: 08 Nov 2012 Location: England Posts: 62 ![]() ![]() |
Stan - how do you change to manual ? |
cancel the folding bit with an iidtool and then just use the button on the drivers switch console.. |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2717 ![]() ![]() ![]() |
It's in the menu between the dials IIRC |
the dip function is but not the folding part...[might be wrong though] |
