![]() | Home > Technical (L322) > Strange Star Wars sound effect from the dash?! |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
i had the same on my 2008, it seemed to happen just before the main ac fan changes speed to get faster, never got any worse or better, I'm assuming it is either something moving baffle wise or some sort of actuator.
r1chardh Member Since: 27 Apr 2015 Location: London Posts: 65 ![]() ![]() ![]() |
It seemed to be happening even with the fans and aircon off - the sound is like a short blip of a dentist's drill - it's distracting! I guess it could still be something to do with the aircon system even while it's not blowing, but I'm not sure. Cheers. |
Herdwick Member Since: 05 May 2010 Location: Lake District, Cumbria. Posts: 36 ![]() ![]() ![]() |
We get 'funny' noises from our sometimes (2012), it seems to be related to the setting of the 'aircon switch' for auto/reclrculate etc.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1424 ![]() ![]() ![]() |
My 2012 WM had intermittent buzzing sounds from the dash. The cause turned out to be some ducting behind the dash not being fully secured. It was repaired under warranty and has not recurred. Only Range Rovers since 1988 |
I'm still getting this sound... could anyone tell me what there is under the dash that might sound like an electric motor spinning up rapidly? I can't work out if it sounds like an electrical fan, or a motor briefly activating.
Just for future reference, I'm still searching for a solution to the noise, and have found this - potential noise from the ECU cooling fan:
Apologies for still asking about this, but please could someone point me in the direction of info on what is under the dash on a 2011 TDV8? I am still getting this strange whizzing noise, which sounds like I'd imagine a toy robot would sound like - a small electric motor spinning up rapidly and repeatedly, maybe moving something like an air vent... So far the dealer has been unable to recreate it, but it happens regularly over the course of long journeys. Anyway, any assistance would be gratefully received, thanks! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35830 ![]() ![]() |
try and make a video of it , then show the dealer... |
Cheers Stan,
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 ![]() ![]() ![]() |
I was (still am) getting a sound like this, but only then turning to the left. I haven't actually sorted it, or opened it to find the exact source and remedy it but on mine it turned out to be the cabin blower, presumably worn bearings, shims or mounts in the fan allowing it to rub against the casing when cornering to the left.
Hi Hamlet,
Fretless Member Since: 16 Sep 2015 Location: Renfrewshire Posts: 162 ![]() ![]() ![]() |
Air sampling fan for the a/c ? Wild guess here... The best 4.4 x far |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1481 ![]() ![]() |
Could it be the hard drive for the infotainment/nav system? 2021 D350 Fifty Edition - Carpathian Grey
It does sound like a fan whizzing up, so air sampling for the a/c is a possibility if that lives under the dash. It happens when all the systems are off, so I wonder if that would still work, but sounds plausible. Equally I suppose it could be a hard drive, though it still happens when nav is off. Again, very plausible.
