Home > Technical (L322) > Air Suspenion Issue
Page 1 of 3 123>
Paul1234002
England 2006 Range Rover Vogue 4.4 V8 Barolo Black
Air Suspenion Issue
Good Morning All,
I have an issue with my EAS. When we have a cold snap I get "Air Suspension Inactive" This only happens when its Cold.
I then reset the fault and all is well. Fault found is reservoir not filling. Anyway fault cleared until the next Frost.
Does anyone know which part of the system is affected or is it all of it.
Thank you in advance.
Post #424703 25th Jan 2017 10:47am
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
I'm not 100% sure but I've heard something about crystals, or something similar in the compressor get damp, i.e. When there's a frost they block the air or something? I think they're meant to dry the air. May be worth a look!
Post #424705 25th Jan 2017 11:05am
Paul1234002
Stacker,
Thanks for the quick reply.
Do you think that I may need a new compressor?
Post #424707 25th Jan 2017 11:17am
Stacker
I don't think so!
As I said I'm not a hundred percent sure, I expect someone will be along later who knows a bit more.
I'm sure the balls (maybe they aren't crystals) can be replaced, I think you can buy replacements!
Post #424708 25th Jan 2017 11:47am
Weegie
Some info on this thread:
http://www.fullfatrr.com/forum/topic40113....compressor
If the granules are too far gone you can get replacements for them. A search on the bay of es comes up with suppliers. John
GAP iiD BT-Sold
Post #424711 25th Jan 2017 12:14pm
miggit
Whistle Make sure that the boot isn't swimming.... the EAS compressor suffers from aquaphobia Laughing Yesterday I couldn't spell Engineer... Today I are one!
Post #424712 25th Jan 2017 12:49pm
Paul1234002
Has any one replaced the crystals in the dryer? and is there a How To available?
Post #425014 27th Jan 2017 10:04am
miggit
Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #425016 27th Jan 2017 10:16am
Weegie
It was all on the thread I linked to. Rolling Eyes John
GAP iiD BT-Sold
Post #425032 27th Jan 2017 11:46am
miggit
Whistle He's new, give him a chance before you hit him with IID tool in every other reply Very Happy
Sometimes it's easier if it's in front of you Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #425039 27th Jan 2017 1:47pm
Weegie
Yes but there is nothing more annoying than posting a reply and it being apparent that the thread hasn't been read. Whistle
Gap iiDs at dawn then. Very Happy John
GAP iiD BT-Sold
Post #425060 27th Jan 2017 2:43pm
Paul1234002
Air Suspension UPDATE!!
As per all the suggestions on here (Thank you). I have carried out the service of the Air Compressor on my L322.
I have changed the Piston Ring, O Ring & the Dessicant in the dryer.
Fired it up cleared the codes Compressor starts then i get an error "Air Suspension Inactive". I plugged in my diagnostic and the only fault coming up was 'Reservoir static".
Cleared this error and again error comes up.
All connections are good i even left the air pipe off from where it links into the cars suspension just to see if any air was coming out and it was although i did think it should have been a bit more powerful than it was, i mean i could put my finger over the end of the pipe. I am not sure what pressure should be coming from the compressor.
The car is now sitting with about 70mm gap between tyre and wheel arch at the front and it looks slammed down at the back.
I have read that the it could be the Air Suspension Solenoid which is around (£450) and i was wondering could this be down to something else before i order the part i think it is?.
Post #427372 12th Feb 2017 7:39am
RP123
Scotland 2006 Range Rover HSE Td6 Bonatti Grey
If the pump is running is it getting hot? The seal may take a time to 'bed'in - Mine got very hot 130c cut out and restatred when cooled off. for some time before it settled down
If running - When I did mine, I seem to remember conecting it up the wrong way - input / output - (it didn't work) Embarassed may cause a sim issue?
My indi told me that the pump is quite low pressure and you can put yourthumb over the outlet to check it's working.
Cheers
Simon
Post #427391 12th Feb 2017 10:34am
Paul1234002
Simon,
Thank you for your reply and wisdom.
The pump did run Hot, so i removed it again in fact i have removed the pump four times checking all hoses and also check that the piston ring was in the correct way.
The car has had the reset done each time the pump was re attached and at least 3 or 4 times after each connection.
Any ideas welcome.
Post #427405 12th Feb 2017 11:54am
alistairh
I did the very same with mine, replaced piston seal and granules plugged it back in and it still wouldn't build up pressure.. in the end the piston chamber was too far gone(scored) to even be able to work after my prior repairs.. looks like it could be a replacement compressor for you..
Post #427411 12th Feb 2017 12:14pm
Page 1 of 3 123>
