|  | Home > Technical (L322) > Charging System Fault warning |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790      | it does kind of sound like an alternator fault it should never charge as low as 12.2v, and is normally over 14v especially after starting or using high load systems, if you have a search on here you will find the 3.6 is prone to alternator failure, the diode pack gives up the ghost. They can be refurbished by the committed, however changing the alternator is not for the spanner shy, and is a little bit involved.  | ||
|  24th Jan 2017 7:09pm |
| Gusfast Member Since: 24 Jan 2017 Location: Somerset Posts: 35      | Blimey, that was quick, thank you.
|  24th Jan 2017 7:17pm |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790      | Have you got the AGM battery or a standard one? They updated to the new battery to help with running the FBH. If you have the AGM battery then you need to get charging system reset to tell it that the battery has been changed. If it's a lead acid battery then it shouldn't need telling.
|  24th Jan 2017 7:58pm |
| Gusfast Member Since: 24 Jan 2017 Location: Somerset Posts: 35      | Thanks for the reply and I'll monitor the readings carefully. I didn't make it clear on the first post, on the 753 menu it has been reading 13.3 -13.5v when running and 12.3-12.5 with the engine switched off.
|  24th Jan 2017 8:39pm |
| wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020      | How many miles has your car done?
|  24th Jan 2017 11:42pm |
| Gusfast Member Since: 24 Jan 2017 Location: Somerset Posts: 35      | Hi Wealy,
|  25th Jan 2017 9:04am |
| mzplcg Member Since: 26 May 2010 Location: Warwickshire. England. The Commonwealth. Posts: 4029      | That behaviour sounds normal for the 2010MY onwards. The charge controller module looks to be doing its thing which is to vary the charge delivered based on the state of the battery and amount of load. It allegedly saves a bit of fuel by turning down the alternator output when it's not needed.
|  25th Jan 2017 12:03pm |
| Gusfast Member Since: 24 Jan 2017 Location: Somerset Posts: 35      | Hi mzplcg,
|  25th Jan 2017 12:08pm |
| mzplcg Member Since: 26 May 2010 Location: Warwickshire. England. The Commonwealth. Posts: 4029      | Yes, precisely that. The original software made the charge control module too sensitive. The update fixes that. | ||
|  25th Jan 2017 12:15pm |
| Gusfast Member Since: 24 Jan 2017 Location: Somerset Posts: 35      | That's well worth a try then. I'll contact my main dealer and ask them about it (and why it wasn't mentioned before, only new alternator, 5 hrs labour, £1000 + ).
|  25th Jan 2017 12:21pm |
|  25th Jan 2017 12:30pm |
| mzplcg Member Since: 26 May 2010 Location: Warwickshire. England. The Commonwealth. Posts: 4029      | Update the software and the message will go away. The alternator is fine, if it was not your car would have a new but flat battery.
|  25th Jan 2017 12:54pm |
| Gusfast Member Since: 24 Jan 2017 Location: Somerset Posts: 35      | Thank you. I'll let you know how I get on. | ||
|  25th Jan 2017 1:03pm |
| Gusfast Member Since: 24 Jan 2017 Location: Somerset Posts: 35      | Sorry, is the update f.o.c or will they charge for it? | ||
|  25th Jan 2017 1:05pm |
| Posting Rules
