![]() | Home > Maintenance & Mods (L322) > 131k mile 4.4 TDV8 in with Cam Tech |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
It's in very safe hands, am sure Craig will make it purrrrr Is this where I put the car details and a bit about myself ?........ |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8795 ![]() ![]() ![]() |
That mileage in that period of time, I imagine it will run like clockwork....
You bored of the Lexus forum already Pete |
batmanreturns Member Since: 16 Jan 2017 Location: Wiltshire Posts: 67 ![]() ![]() |
It does run well, the precious owner bought it new and it's just sat in top gear on the motorways which is perfect for modern engines. Getting new fluids so it's ready for another 131k! It's in great condition too, only minimal wear and a handful of stone chips which I guess is the advantage of being higher up!
They just talk about polishing... one guy was moaning like ![]() It's like a different world... ![]() __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior -Click here for Thread- 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click here for Project Fatty off roader- |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35829 ![]() ![]() |
get Craig to change the front and rear diff oils and transfer box oil... |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
^^^I was going to suggest that, you will be glad you have and you will know it has been done. the oil are not cheap per liter but you only use a small amount so this is realy something worth doing.
If only £38 in 6 years was our FF reality ![]() ![]() Glad your sticking around for the banter ![]() |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1672 ![]() ![]() ![]() |
Fuel filter too? Not expensive and easy to do as a DIY - see the Wiki.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6830 ![]() ![]() ![]() |
^ you might need to bleed the fuel system after you change the fuel filer. |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
is there ANY repair (other than light bulbs) that cos'ts less than £38 on a range rover ?? |
replacement dust caps. |
^ only if you do them 1 at a time |
