Home > Maintenance & Mods (L322) > Brake light LEDS
stwid
Brake light LEDS
Hi All,
I am in the process of changing the individual LED's in the rear cluster of my 2004 Vogue due to some of them failing. I am wondering if any one had done this before, if not i will do a write up for this process.
Many Thanks.
Stuart.
Post #424844 26th Jan 2017 11:20am
unusual for those to fail and i've not heard of it on the forum..is the 19 led brake cluster not a sealed unit ?
Post #424847 26th Jan 2017 11:36am
i can see why you're attempting to replace the individual leds as the 'circuit board' costs around £100...
would taking this circuit board from a damaged rear light unit be easier..
Post #424853 26th Jan 2017 11:47am
miggit
Whistle I've got a broken light, gathering dust Whistle Yesterday I couldn't spell Engineer... Today I are one!
Post #424880 26th Jan 2017 2:50pm
I've got one of those led clusters in full working order lying in my box of useful bits doing nothing if it is of any use to you. Thumbs Up
Post #424882 26th Jan 2017 3:28pm
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
Are we on about the high level brake light here?
Mines got 3 or 4 leds out, and I've just bought a second hand tailgate without the rust - the lense is broken on that one!
Not sure whether I can make one or not out of the two! I look forward to hearing how you get on!
Post #424941 26th Jan 2017 9:13pm
The OP said it was the cluster, so I doubt it.... Thumbs Up Pete
Post #424943 26th Jan 2017 9:28pm
Stacker
Ah my bad.
Didn't think the 2004 Vogues had Leds in the cluster, my 2002 is just two lamps! Sorry
Post #424953 26th Jan 2017 10:02pm
You will find the brake lights are LED'S in your year, they all had them, the bulbs are for side lights and indicator... Thumbs Up Pete
Post #424959 26th Jan 2017 10:29pm
it would make sense if the OP was talking about the high level brake light as these do sometimes burn leds....
we wait in anticipation !..............
Post #424961 26th Jan 2017 10:34pm
Stacker
You're right as well... I was thinking the tail light as you said sorry mate!!
Wonder if my brake lights have any out now!
Post #424963 26th Jan 2017 10:46pm
stwid
Hi,
It is the 19 LED cluster, I have just repaired mine for about £4 It takes a little time with a good soldering iron. Mine had 4 failed LEDS and it took the whole cluster out.
Thanks.
Stuart.
Post #424996 27th Jan 2017 8:30am
thanks for the info stuart Thumbs Up
Post #425002 27th Jan 2017 8:47am
