![]() | Home > Technical (L322) > Positive battery terminal |
| steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208
The trouble is, the +ve clamp also incorporates something else (not sure what) and is a single piece to alternator and start motor, so not as simple as replacing it with an ordinary battery clamp. The replacement cable is part no. YMS500340 or LR012380. An expensive battery cable! I'm not sure it would be a good idea to graft clamp to the existing new cable - I'm sure it would be possible, but you'd want to be very careful about getting a very low-resistance joint because of the high currents involved.
| holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086
Does ithe cable have the battery disconnect unit on the later models which fires off after a crash ? |
| Wogger Member Since: 12 Jun 2016 Location: Nottinghamshire Posts: 407
Cheers Steve
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3276
Make sure it is pushed right down on the post. If it is even slightly up it won't tighten. John
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
As above, but if yOh are attempting to fit a bigger battery then some fettling is needed. There is nothing that can't be fixed with a hammer😜😜
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3668
The +ve clamp has a box like thingy on it, and a couple of more wires.
The box type thingy is the explosive type thingy as mentioned above by miggit and can be sensitive and throw an SRS fault.
Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
Right start from the beginning........
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8135
This thread needs a photo for useful advice to be provided |
I've found this for the BMW... which is basically LR up to 2005, and Ford didn't change everything so I imagine that they are still these.
| Duracell777 Member Since: 07 Sep 2015 Location: Warwickshire Posts: 128
Or
