Home > General > Jobs list is slowly dwindling..
alistairh
Huge thanks to everybody who has assisted my cries for help bringing my car up to scratch.. I got the fatty in July from a friend who upgraded to the newer vogue and had quite frankly let the car slip..
Since July I've managed to-
Diagnose and refit new air compressor and valve block..
Remove and re finish foundry grey interior plastics.
Unblock sunroof drains.
Do my first oil change . Engine and diffs.
Source and learn how to safely remove the fattys battery without blowing a finger off or wiping an ecu or 2 Laughing .
Refit new tailgate rubber seal and solve my watery boot problem.
Fit new heated steering wheel after diagnosing the old one had died.
Fix rear door misalignment and stop the water coming in and lying on the sill..
Replace all filters in the car
Resynch keys to car after replacing af receiver..
Fit new headlight and indicator unit
Fit 2012 led rear light clusters
Replace every single bulb in the car with led
Calibrate cars height properly
Remove and refit new Pcv valve and all hoses
I still have to fit thermostat mod and flush and replace coolant, fit new seat base covers, drivers and passenger side then hopefully pluck up the courage to fit new brake pads and disks..honestly don't know what all the above work would have cost me from an Indy but I'm delighted to have been able to do the graft myself so a huge thanks to every single member who has been patient with my constant posts and my non ability to properly use the search function/wike Laughing
Post #424332 22nd Jan 2017 9:51pm
Spelunker
England 2003 Range Rover Vogue Td6 Zambezi Silver
Sounds like you'r getting to grips with things and like me you enjoy getting your hands dirty - no bad thing as an FF owner.... QUID FACIUM TIBI
ANTEQUAM ALIIS
2003 TD6 VOGUE Zambezi Silver
tows 2006 Lunar Delta 540/2
Post #424956 26th Jan 2017 10:24pm
alistairh
Yeah I'm slowly beginning to understand basic mechanics.. brake system overhaul in the next few weeks .. that's probably my biggest job to date..
Post #425081 27th Jan 2017 6:27pm
rar110
Thumbs Up ______________________________
Post #425132 28th Jan 2017 12:41am
Spelunker
Side light bulbs.
Decided to go with the ever increasing crowd and changed the front sidelights to led today - 10 minute job and what a difference. Not sure where it stands re MOT though, will I have to swap them back for the test? QUID FACIUM TIBI
ANTEQUAM ALIIS
Post #425260 28th Jan 2017 7:56pm
alistairh
I think you are ok! My mate mots my cars and he's aware I've done the sidelights/reverse and licence plate bulbs with led and hasn't said a word so I presume it's all good.. Thumbs Up
Post #425267 28th Jan 2017 8:12pm
alistairh
They do look good compared to the old yellow bulb though!!
Post #425268 28th Jan 2017 8:12pm
Well done on that lot...
Get the thermostat mod done ASAP... the gearboxes run at a silly high temp due to the high engine coolant temp...
Heat is the worst enemy of auto gearboxes... Thumbs Up Pete
-Click here for Thread-
Post #425273 28th Jan 2017 8:22pm
alistairh
Cheers Pete.. I've got the stat sitting in the garage next job then brakes.. cheers for the pointers over the past few months.. been a great help! Thumbs Up
Post #425277 28th Jan 2017 8:37pm
