Home > Maintenance & Mods (L322) > Rear wash/wipe leak repair.
Zeb
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
With the help of the excellent how-to in the Wiki I attempted this today. However, having swapped out the original seal with a new one, then replaced everything, I then found the leak remained owing to the spindle having corroded. Having clocked that there was actually room for two seals - with the additional seal further back along the spindle and away from the corrosion I decided to add a second seal.
Looking at the motor with the trim cover off, I came to the conclusion that you can do this repair in situ, with a little care, thus saving a fair bit of time and effort. Just thought this might speed up the process for people yet to do this repair / mod.
Post #425429 29th Jan 2017 4:54pm
Add that useful info to the article in the wiki, no one will see it here when they do the fix... Thumbs Up Pete
-Click here for Thread-
Post #425483 29th Jan 2017 8:29pm
Zeb
T'is locked so needs someone more important than me to add it. 🙂
Post #425487 29th Jan 2017 8:39pm
Baron
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
How long does this leak take to start? I have a Nov 2010 manufactured facelift L322 and intend to keep it for another couple of years or so. Does the face lift model also suffer with this problem? I'm wondering if I should be doing a bit of preventative maintenance? Current: Volvo XC40 T4 R-Design. Loitering with intent to possibly buy back in.
Previously: 4.4 TDV8 Vogue Baltic Blue MY11
Post #425509 29th Jan 2017 10:10pm
Zeb
Hard to say. Mine is 10 years old and has just started but if you were to get on and replace the seal with two seals then it would prevent the spindle from corroding in the first place!
Post #425513 29th Jan 2017 10:19pm
Zeb
Could this be added to the Wiki please? Saves a good bit of time and effort if you are just repairing the leak!
Post #425820 31st Jan 2017 11:42pm
