![]() | Home > Technical (L322) > Blown Xenon & inactive suspension |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6420 ![]() ![]() |
The LCM (Light Control Module) picks up a fault for the suspension, this is probably recurring, once it finds a problem with the bulb. Hopefully will go away once new bulb fitted, if not codes to be read and cleared! Unless of course you got two faults at once, and it was just coincidental! (It is a Fullfat after all |
cropps Member Since: 07 Aug 2014 Location: Lancashire Posts: 32 ![]() ![]() ![]() |
That was my train of thought, hopefully it will clear as it had cleared for a while this morning |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
The xenon bulb blowing can cause some really bad faults, SaintV8 on another forum lost communication to the OBD port when his bulb blew and months later it connected ok again if I recall correctly. Do you have any diagnostic kit ? |
No good stuff just a cheapo engine check one, i will try & see if it still works.
It may just be a coincidence or needs some other faults cleared, they don't need much of an excuse to throw an EAS fault. |
Postie took my bulbs back to post office!!! must not be my normal one as he would have left them, so hopefully i will get them tonight after i get someone to pick them up today. On a positive note the Air suspension has stopped failing, it was good going home last night & this morning. |
New bulbs fitted, all has returned to normal. |
