Home > Technical (L322) > Transmission problem
Eamonnjack
Canada 2006 Range Rover Westminster 4.2 SC V8 Barolo Black
2006 full size Range Rover supercharged . Fault code p0960
About 3 weeks ago car was started outside temp minus 20 dash showed transmission fault limited gears only . Drove car about five miles now warmed up turn car off restarted no fault on car drives normal . Plugged in scanner and code p0960 . Had to use car as in middle of nowhere trying to sort problem . And same thing when cold limited when warm turn off and on and normal . Then it start to hold fault all time . What we noticed was trans pipes weeping so thought change them and cooler and check level . Got pipes from England changed dropped oil out of trans sump didn't change filter just wanted to see I it could be oil level but still have same fault code .
Any ideas ?
Post #425686 30th Jan 2017 9:31pm
Sounds like a solenoid gone in the valve block, you can get these checked.... Thumbs Up Pete
Post #425706 31st Jan 2017 12:57am
Eamonnjack
How do you test them?
Post #426260 4th Feb 2017 4:27pm
Eamonnjack
Where's the best place to buy them from
Post #426270 4th Feb 2017 5:48pm
