![]() | Home > Maintenance & Mods (L322) > Biggest battery in a 4.4 l322 m62 |
| Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2299
Hi all I am after a 120ah agm battery for my ff - will any fit? |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
Get out a tape measure and see... just measure how much room is around the battery you have and take it from there...
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3669
Stick with an 020 and if you want more power then add an 019 in the boot!
The reason I ask isn't because mine is bad - but if you leave the sidelights on for 5 minutes (no joke) it's completely flat.
The 019 is the std battery for the petrol cars... but they have the same battery tray as the diesel that sports the 020, so it will fit. If your battery is old or has been totally drained then it probably isn't holding charge properly... even if it has enough to start the car, it still might not be a full charge, which should start the car several times in succession without any trouble. The fact that 5 mins on the side lights is enough to kill yours, sort of makes me think that either your battery is fubar'd or you have a large drain still going when the car is switched off |
| All times are GMT |
